Another 9 bolt ?
Old Aug 7, 2005 | 09:28 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
Axle/Gears: 9 bolt 2.77
Another 9 bolt ?
If my car has the 2.77 gear am I stuck with that?, or does someone make a 3.73 gear for my carrier.
Old Aug 7, 2005 | 09:48 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm wanting to think that you can only put a 3.73 in a carrier that originally had at least the 3.27 in the 9 bolt.
Old Aug 7, 2005 | 09:54 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
You'd have to upgrate to a 3 series carrier as stated above. Meaning a carrier from a rear that had/has 3.27 or numerically higher gear ratio.
Old Aug 7, 2005 | 10:03 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
So anyone that wants to upgrade there rear and has a 2.77 carrier is SOL?
Old Aug 8, 2005 | 05:40 AM
Fastrnu's Avatar
Car: 92 RS
Engine: H/C/I/E LS1
Axle/Gears: 4.10
Maybe not SOL. I'm waiting on some replies in another post to make sure the info I have is correct but you can get new parts from AUS. The diff is a newer design but should work, based on info I currently have. I don't feel the price is too terrible either.
Old Aug 8, 2005 | 06:56 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
www.9bolt.com
check them out, i'm pretty sure he told me the 9-bolt carriers were large enough to fit all sizes from 2.77 to 4.10+
Old Aug 8, 2005 | 11:22 AM
Engine: LB9/383
Not SOL, just need a carrier. Shouldn't be too hard to find one. If you put a 10 bolt 2 series and 3 series carrier side by side you'll see the difference. It's kinda hard to describe in words, but it's got to do with the spacing of the ring gear (side to side) to mesh properly with the larger diameter pinion.
Old Aug 8, 2005 | 12:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally posted by Cruz'N Bruz'R
www.9bolt.com
the housing is
the carrier whould need a spacer ring or a thicker ring gear(which is not made to my knowledge)
I had some pictures of both series carriers next to each other but are wonderful search eng. can't find that post
now you could have the spacer made but, the carrier is not that hard to come by
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
