t5 manual trans power
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
does anyone know how much torque and horsepower a 93 wc t5 can handle
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It can handle 150hp or 1000hp. It all depends on how you apply the power. The WC T5 is not known for its durability when applied to high power applications. There is no set value for its demise.
There was no '93 3rd gen T5. I am not sure if the 4th gen V6 cars even used the same WC T5 for that matter either.
Car: 85 camaro z28
im looking at a t-5 on ebay that the seller claims came from a 93 v8 camaro 4th gen of course. i wasn't sure if the 4th gen firebirds and camaros had an option for a 5speed or a 6 speed. if anyone knows how strong the t-5 is for a 93 camaro v8 let me know please
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
They used T-56's in 93 and up cars. If it's a T-5, it's either older, or from a v6 car.
The WC T-5 was 'rated' up to 300ft lbs of tq. But driven properly, they handle a great deal more. The T-56's were rated to 400ft lbs and 450 ft lbs. Both numbers are pretty gay.
Car: '90 RS
Engine: 377 LSX
Originally posted by n8sz28
does anyone know for sure that the t-5 application wasn't used in a 93 v8 camaro
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
NWC T5 used in V8 F-body applications from '83-'88 rated to 250 lbs/ft
WC T5 used in V8 F-body applications from mid'88-'92 rated to 300 lbs/ft.
ALL 4th gen F-bodys with a V8 used a T56 if they were stick. The '93 T56 is rated to 350 lbs/ft. '94-'02 T56s were rated to 450 lbs/ft.
4th gen F-bodies with the V6 used a WC T5. The guts are the same as a 3rd gen V8 WC T5, but the case is different, and it can't easily be mounted to a V8 bellhousing. I'm trying to find adapter plates for this swap. 4th gen WC T5s are plentiful and usually unabused, whereas WC V8 3rd gen T5s are getting scarce, and they often need hard parts due to damage from abusive driving.
Speaking of which I am interested in your T5 dennis. PM me, I've already got a buyer lined up and need a good core to build a G-Force trans on.
Using G-Force internals a T5 can withstand 500+ lbs/ft. It's a pricey proposition though, but probably still cheaper than a T56 swap.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am willing to get rid of it for 300 obo.
A little more info on it...
It had 98K miles on a TPI motor.
I drove it from 84K to 98K with 0 problems.
I replaced the fluid cuz i was bored.
All seals got changed when I got a new clutch back in the day. (i no longer havea clutch for it.)
I do have a throw out bearing I can give the buyer.
Stock shifter
No cluncking, sliding out of gear or anything like that. I can take pics of it tonight when I begin my lambo door install. i will have to move it from my garadge to my room I guess, to make room.
Still interested, PM me
Stock shifter
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
