can get a posi????
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
can get a posi????
hi,
heres the info on my current iroc's rear end:
(on the carrier) GMD5 5387
(on the ring is) GM-1 (large space maybe numbers wore off) -12:41-7 5/8
i understand my iroc has 26 spline axle gears.......can i just put in posi internal parts without removing the carrier???? what do i look for when finding these parts to go into my current carrier.
What is the differences between 9 and 10 bolt rear and how can i tell by looking.
reason i dont wanna swap the whole unit is i was hoping i can just get posi carrier guts only(stock or aftermarket) like used, on here maybe and shipping to me in canada is not to much. I have to drain the rear again in spring to replace a axle seal anyhow so it would be great to swich to a posi at the same time.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Count the # of bolts that hold the inspection cover on, it wiil 9 or 10. Your 7-5/8 would be the ring gear size which is a 10 bolt. Your open carrier can be swapped for a posi one, the gears will need to be set up for proper backlash & pinion depth with the new carrier. If you intend to change rear ratio with anew ring & pinion, the time to do it would be with the new posi carrier. They can be had new or used, aftermarket or OEM. Summit, Jegs & probably a hundred other companies sell them online or through mail order.
Car: '81 Trans Am
Engine: 6.6L
see but i dont wanna have to take out the carrier if i dont have to??? can i just get the rid of the guts of the open carrier and put in posi stuff or does it not work like that do i have to replace the whole carrier to change to a posi??? know what mean??
And the ratio i dont know... is what i have good enoght... any ideas maybe what i could change to and what difference would it make???
Car: '81 Trans Am
Engine: 6.6L
Originally posted by Ricktpi
The Powertrax unit is the only one I know of that uses your open carrier.
Check Summit or Jeg's. I believe they both sell them. I do not have any first hand experience with them. Do a search on this board. I am sure quite a few members here have them.
Car: '81 Trans Am
Engine: 6.6L
ok thanks man i did and looks like the powertrax is too expencive for me 400 and up easy (not including exchange). So looks like im ganna havta do a whole swap maybe in the spring....
cheack out this i seen at ebay would this fit in my camaro??
http://cgi.ebay.com/ebaymotors/7-5-G...15617906QQrdZ1
Just because it's made by Eaton, doesn't automatically make it good.
What it is, is a truck unit, designed for off-road use in low-traction situations. It acts like an open, until the RPM difference between the axles exceeds about 150 RPM; at which point the little governor weights cause it to lock up with a bang. In other words, you have NO LIMITED SLIP ACTION WHATSOEVER at a standstill, and NONE OCCURS until AFTER wheelspin has already started. So it creates an automatic loss-of-control problem on pavement.
Then, look at the sizes of all the parts and pieces. They're little bitty weenie things. Even the S truck people grenade them with 4- and 6-cyl motors, on pavement.
KO1
16
Oct 15, 2015 05:00 PM
