Reverse Not Working Help
Old Dec 22, 2005 | 05:09 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
I put it in reverse and heard a thunk and then reverse no longer worked...Then all the sudden the whole engine started smoking and coolant came rushing from under the car. WHAT HAPPENED.
Its a 92 Rs Camaro Auto
Old Dec 22, 2005 | 07:21 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Ouch! What did you do a neutral drop. hahah JP. If you ask me you got problems but no really check these things out.
My thoughts
Your radeator took a massive dump in turn causing your trans to lose fuild if you have trans cooler lines running to the radeator.
First things first check under the hood, under the car then come back and post your fiinds more details the better. BTW check all your fuilds too. can't help you with out details
was it hot cold running bhal bhla
Old Dec 23, 2005 | 11:22 AM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
ok so i checked under the hood. And i found where the coolant came from it broke a heater core hose connector so i replaced that. I didn't see anything obviously damaged under the car. I did notice that i have a cable under my hood right next to the carberator that has a screw coming out of the end but i don't know if it was like that. The fluids levels where all ok besides the obvious coolant. It was hot when it did this and no i didn't do a nuetral drop. I was just backing up and heard it.
Old Dec 25, 2005 | 09:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
that happened to a car I used to own. does you car have a clunk when it shifts from 1-2 under acceleration.
camaro11j
Sep 19, 2018 08:49 AM
Fronzizzle
Aug 17, 2015 02:52 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
