Slave Cyl Hydraulic line?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
That crappy plastic line that they use for slave cyls broke. Where can I get some or use in its place. I tried rubber hose and guess what. Bad idea. Any takers?
Car: 1991 Formula L98
Axle/Gears: 3.73:1
What kind of connection is there on the slave cylinder? If there's a way to attach a fitting to it (ie, if it is threaded), I would convert to a braided line. On the T-56 there is a braided line with a special end with an o-ring and a pin that holds it in place, which works well. I converted mine to a male 3AN fitting and bought an Earl's 3AN pre-made line for $15 or so.
I've never seen the pieces used for a T5, so I apologize if this is not of any use to you.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
t-5 and t-56 ends are the same, a T-56 hose is already braided, and will work in a T-5, but it will be abit long
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Upgraded mine with fittings from Mcleod & had a -4 braided steel line made locally.
Car: 86 IROC-Z
Engine: 97 LT1
"I converted mine to a male 3AN fitting"
Excuse my ignorance but what is a 3AN fitting? I purchased a McLeod hydraulic TO brearing which has a threaded connection on the hose. I want to connect it to a 97 Camaro OEM Master cylinder with the connection discribed above. How can I convert one or the other?
Check this thread out. The threaded end of the fitting in the picture is -4AN, -3AN slightly smaller. BTW Mcleod recomends -4. -3 is a little small for quick clutch reaction.
https://www.thirdgen.org/techbb2/sho...d+fitting+call
Car: 86 IROC-Z
Engine: 97 LT1
Thanks for the help. I spoke with Bernie at McLeod Ind. and there are two types of adaptors. Part # 139026 a straight connection to the Master Cylinder and Part # 139027 a 90 deg connection. The braided line come in various lengths Part # 139100-24 is a 24" hose. This puts me one step closer to smoking some tires.
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I need hydraulics for a t5 swap
Can I use the one for the t56 or is that
a bad idea?
It looks very similar and uses braided line
which is better.
a bad idea?
which is better.
Car: GTA
Engine: 383 HSR
139026 EA 38.75 0.00
FITTING MALE ROLL PIN END TO AN4
139027 EA 43.40 0.00
FITTING MALE ELBO ROLL PIN TO AN4
139100-24 EA 44.95 0.00
LINE HYD STL BRAIDED 24"AN4 FEMALE
(Not including tax & shipping) Total 0.00
$40 for a fitting sounds a little steep and 45 bucks for 24" of SS line is a ripp off. You can get 3 Ft of AN4 for 14 bucks at summit.
But I cannot find a roll pin to AN 4 adapter. Anyone help me find a cheaper source? I need two straight ones. I hate to spend $80 bucks for two small fittings!!!
BTW, I have an extra -4 SS line with -4 female an fittings 13" long I can sell for $25 + ups. I had a line made 26" & it was too long. So I had it cut in half & two more ends crimped on.
Car: GTA
Engine: 383 HSR
I have all the SS line I can handle right now, If you have the fittings that are roll pin to AN 4 I would be interested. I refuse to be ripped off for such a small and senseless item, I will just tap out my slave cyl and put a regular fitting in it and yes I know there is a hole because of the roll pin but I have a solution.
Car: 85 corvette
Transmission: t-56
Re: Slave Cyl Hydraulic line?
sorry to bother you but i was reading through the forum and saw that you at one time had the same problem as i am currently having. we are putting a t-56 tranny into our corvette. I have bought the clutch master & slave, but cannot find the line that goes between the 2. i have contacted gm and they said they only sell it as a 3 piece kit (master, slave & line) and its gonna cost me 3x's as much as what ive already paid. do you have any suggestions for me on what you ended up doing?
Engine: 383
I ended up using a line I salvaged from a '95 TA that had its front end wiped off it by a tractor trailer truck, it tore the master cylender off the firewall, and ruined it, but the line works fine
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Not sure if this helps, but I bought my T56 hydraulic kit complete & pre-bled for $167 shipped from http://tpiparts.net/inc/sdetail/819
They were a lot cheaper than what the GM dealership wanted.
Car: 85 corvette
Transmission: t-56
yeah i absolutly couldnt find the line around here, scoured the bone yards and all they had were automatics or just the frames. i even went to a hydraulics company to see if they could make one for me. i ended up finding the 3 part set from a company in arizona, $149 shipped, should be here in 2 days. thanks for the advice!!
Car: 1985 trans am
Transmission: t5
im having the same problem with my 85 305 and t5...my plactic line if fine but the fittings snapped off inside the line...n all i need is the line with the two ends...i dont really understand what your saying can anyone help me
Car: 1984 Monte Carlo SS
Transmission: WC T-5 (in a month or so)
Russell makes those same fittings, they sell for $20 a pair from Summit. Russell PN 640281, a Russell AN-3 line should be about $18-20.
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
ok r we talkin about the t5 or a t56 with the hydro troughout, im putin a 4 speed in and lookin for the cheapest way to do it cuz i dont want to go with a mechanical clutch.
but if i got the fitting and a an4 line and the t56 bearing will it all work?
The fitting above will fit either clutch master, 84-92 or 93-97. I do not know on the 98-02 because I have not used one for the LS1 tranny. The fitting from Russell is AN-3 though not AN-4.
topteam54
Oct 6, 2015 12:21 AM
armybyrd
Sep 15, 2015 06:06 PM
