speed recalibration help needed badly
Old Jan 25, 2006 | 10:10 AM
rock'n z's Avatar
Car: 88 camaro iroc
Engine: 5.7 tuned port
Transmission: 700 r4
ok heres the problem i put 3.73's in the rear of my 88 iroc i know i need a 15 drive and a 45 driven i got the gm parts useing the pt# sethirdgens gave me the problem with that is that the 45 driven gear only works for electronic speedos and i have a mecanical driven speedo that gear had a 1/4 inch of play on my mechanical gear shaft for the speedo...... gm tells me they dont make that 45 tooth for the mechanical driven speedo soo they said they have an all plastic one for a 77 most likely a 350 trans can anyone help me get the proper gear i need to have a workin speedo???
Old Jan 25, 2006 | 10:19 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
8642620 is a 15 tooth drive gear
25522497 is a 45 tooth driven gear & comes with the sleeve.
Old Jan 25, 2006 | 10:28 AM
rock'n z's Avatar
Car: 88 camaro iroc
it will fit the 700r4 with no problem??? and is that a gm pt#???
Old Jan 25, 2006 | 10:42 AM
Ricktpi's Avatar
Yes & yes. These are for a 1987 Camaro 700R4 with a mechanical speedo. Been through this many times & I work for a GM dealer.
Old Jan 25, 2006 | 10:48 AM
rock'n z's Avatar
Car: 88 camaro iroc
thanks very much man i just ordered it and it will be in tomorrow i really appreciate the help
Old Jan 25, 2006 | 03:02 PM
fast83ta's Avatar
Car: 83 Trans Am
i have 323s stock in 83ta with a 700r4, my ? is i am going to 373s will those part numbers work for me
Old Jan 25, 2006 | 03:04 PM
fast83ta's Avatar
Car: 83 Trans Am
i am not changing the gear on the input shaft only the gear that the speedo cable screws to. thanks
Old Jan 25, 2006 | 04:04 PM
Ricktpi's Avatar
The factory setup for 3.23 gears is 17 drive & 44 driven, pn's 8640517 & 25522495 respectively. 38 tooth driven with a 15 tooth drive is not ideal for wear.
Old Jan 25, 2006 | 04:50 PM
drjohn981's Avatar
Car: 86 iroc z28
Transmission: t5
Axle/Gears: 4.10 10 bolt posi
86 Iroc z - now has t5 with 3.23 ratio rear. Got a t56 tranny, which probably won't go in till 07. Will put in 3.73 rear in at same time. Can I use cable driven speedo - if so which drive/driven gears to use?
Old Jan 30, 2006 | 04:27 PM
fast83ta's Avatar
Car: 83 Trans Am
speedo gears
ok ricktpi i really appreicate the info but i was still wondering, u said from the factory, for 323s i have 17 and 44. i want to know with putting 373 in what driven gear do i need. u r a HUGE help. thanks
Old Jan 30, 2006 | 07:30 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I'm glad I'm not the only one in the dark about the speedo gears. I have a 1989 Formula, T5 w/ 3.73 rear gear and 25" diam tires ("16s"). Rick, can you point me in the right direction too?
If not I understand you're not here for a free consultation. Thank anywho...
Eric
IROCZ1989
Jan 24, 2016 03:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
