Standard VS AUTO?
Old Feb 16, 2006 | 11:07 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
Standard VS AUTO?
I have looked everywhere for this one question that i have. Would it be better to have a Auto because it has a tq converter and makes more tq than a standard? Or is there no diffrence between the two? standard sounds nice because theres no feeling like shifting gears in a v8 thrid gen but would it be worth the work of hunting down peddles and other stuff like that?
Old Feb 17, 2006 | 06:19 AM
ede's Avatar
ede
i think you're confused. i torque converter don't make torque, it also doesn't make more torque than a standard. tell us how exactily you define "worth it" and what you goal is and maybe someone can quantify an answer as to what you should do.
Old Feb 17, 2006 | 07:45 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The "best" one to have is the one you enjoy. I, myself, prefer an auto. Based on the production numbers from manufacturers, most people prefer the autos. Most enthusiasts prefer a stick.
Buy what you like and enjoy the ride.
Old Feb 17, 2006 | 09:34 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Not to thread jack...
Only way to go
Max
Old Feb 17, 2006 | 09:40 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
The purpose of torque converter is to converte your engine torque from standard unit Ft/LBS to SI Metric unit which is N/M J/K.
To convert from manual to automatic, you need the these parts:
1. Flexplate
2. Auto Transmission from an F-body
3. Gas/Brake pedal assembly
4. Upper console swap with Automatic plate
5. Automatic shifter
6. TV cable
I hope this will help.
Old Feb 17, 2006 | 11:20 AM
3rd gen V8's Avatar
I have benn learning about auto tranys in school and found out that a stall converter will nearly double your tq output at stall speed. But if there is no difffrence between the two then i gess ill try to go for the the t56 swap then. about how much would this swap be?
thanks
Old Feb 17, 2006 | 01:08 PM
ede's Avatar
ede
you ought to relearn the torque converter chapter, all torque converters are "stall converters". sort of like saying ration rockers, or ratio gears, they all are. there's no way you can flatly state a "stall converter" double the torque output of an engine. what a converter with a higher than stock stall speed will do is let an engine get into it's power range before the car moves. to optimize it you'd need a converter wit ha stall speed equall to or near to your engines peak torque.
Old Feb 17, 2006 | 11:33 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Auto vs manual
Now we talking about stall!
Hay lets get back to the subject
See the link
Paddle Shifter, solution to the auto vs manual thing
Old Feb 18, 2006 | 09:17 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Thanks for the link. Good read
sp8ty
South East Region
Sep 24, 2018 03:55 PM
gixxer92
May 18, 2017 11:20 AM
Gunner242
Dec 25, 2015 04:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Bigold4x4
Sep 28, 2015 05:21 PM
