Drag radials+stock rear=bad?
Old Mar 24, 2006 | 05:18 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
OK so I just put a new motor in my ride and its not running yet but i'm hopin for somewhere around 500hp on spray. My question is would it be a bad idea to run drag radials with the stock rear? I was thinking with that much hp and all the traction the rear might blow? I have a heavy duty rear cover and richmond gears. Think drag radials/slicks are a bad idea?
Old Mar 24, 2006 | 07:12 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
bad ideal?only if you've grown attached to that rear end.it'll only be a matter of time before the rear gives way.
Old Mar 24, 2006 | 09:08 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Seems like a touch over 400 wheel HP is the limit on a sticky tire. Automatics are more forgiving. Seen plenty of local Fbody's running around with 400-420HP going low 11's on stock 10 bolts. You'll be OK if you run yours on the motor but if you spray it out as much as you said you will, you'll break it. Especially if you're spraying it out of the hole.
Old Mar 24, 2006 | 02:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
9 bolt with ET Streets and 383 with no problems
Old Mar 24, 2006 | 03:20 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
the nine bolt is a little bit of a stronger rear end then the ten bolt.
Old Mar 24, 2006 | 03:38 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
i dont plan on sprayin out of the hole, i guess i will lay off on the drag radials and see how it holds up on regular street tires first, thanks
Old Mar 24, 2006 | 07:31 PM
Dialed_In's Avatar
run it on the motor with the drag radials. you'll be fine.
Old Mar 25, 2006 | 01:30 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
I really like the "DO NOT PRESS" link in your sig... i was at it for about 10 min.. lol!
Old Mar 25, 2006 | 10:59 PM
Engine: 355 chevy
lol
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
