2.73 to 3.23 pinion problem
Old Mar 30, 2006 | 12:25 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
I have a 1990 2.73 posi with drums and took the ring and pinion from a '91 v6 with 3.23 gears. The ring was, no problem. The pinion felt like if it's not meshing well with pinion. D'oh! Do I need to shim the pinion? Any advice would be greatly appreciated.
I love working on my car but I don't want to invest $100 or so on a dept gauge that I'll probably only use once. Also, where can one buy that marking compound I keep reading in other threads? I’m willing to try it.
One more thing, the magnet on the inspection cover was removed to clean the part. Can I use JB weld to glue it back on?
Old Mar 30, 2006 | 07:33 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
2-Series carrier (2:73) and you installed 3-series (3:23) gear & pinion, so that is is your major problem. Your parts do not match, so you did No research on this project.
Old Mar 30, 2006 | 08:35 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes, you were tring to install 3 series (3.23 up) gears on a 2 series (3.08 down) carrier. You can buy a kit to install it which is basically just a high precision shim, or you can buy gear sets that are deigned to fit different series carrier (ex. 3.23 to fit 2 series/2.73 to fit 3 series)
Old Mar 30, 2006 | 10:40 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Got it, 3.08 down 2 series. 3.23 up, 3 series. So I guess I'm stuck with 2.73's but I just might look for some that will work with 2 series carriers.
Old Mar 30, 2006 | 11:00 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Your not going to be pulling them out of anything in the junkyard, you might get lucky in the classifieds section though.
Old Mar 30, 2006 | 12:05 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Looked up Richmond gears. #4900031 will work but $220, ouch!
84z28350, where can I get that shim kit? Summit or Jegs?
Old Mar 30, 2006 | 03:05 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Just buy the spacer. You can get them from speedway.
http://www.speedwaymotors.com/xq/asp...qx/Product.htm
91048305 RING GEAR SPACER 7.5"GM W/BOLTS
RING GEAR SPACER/7.5"GM
EA $44.95
Old Mar 30, 2006 | 10:34 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
my3rdgen, thanks for the link. But it looks like I'll be buying some 3.23's for my 2 series. My neighbor who's a damn good mechanic was pounding off the pinion, it came flying off and got chipped pretty good. At least v6 rear ends are everywhere out here. Once a month they have a half off sale.
Jeg's has some that will work on my 2 series, will I still need a shim kit?
Old Mar 30, 2006 | 11:06 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
You won't need the spacer.
Not if you buy a new 2 series gear that is the 3.23 ratio you want. I suggested the spacer so if you had a good cheap used 3.23 you could still use it. But since that is out of the question now, and you are buying a new gear, just get the 2 series 3.23.
Old Mar 31, 2006 | 12:04 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Thanks again, my3rdgen! I noticed you have 3.73's, did you also do a change over and what brand of gears did you go with? Just wondering because 3rd gen's didn't come geared that low.
Old Mar 31, 2006 | 01:05 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
The rear end on my TA, since it was an 87, had a 26 spline carrier and axles. I got a 3 series 28 spline posi off ebay, then bought a Richmond Gear 3 series 3.73 ring and pinion. I could have gone to the bone yard and got a set of used 28 spline axles from an 89-92 3rd gen car, but for $275.00 I got a new set of alloy axles from Moser.
I should have used a set of 3.73s from an S-10 in the bone yard and a used set of axles. I don't know about where you live, but these parts are in bone yards everywhere here in the midwest (you just got to get muddy and go hunting).
I could have saved around $300 to $400 buying used vs new. You could probably buy all the used parts (posi, 3.73, and axles) from a U-Pull-It type wrecking yard for around $100.00 or less. Then get an overhaul kit for the rear for $125.
Old Mar 31, 2006 | 01:54 PM
Pat Hall's Avatar
Actually, some of the earlier thirdgens did get 3.73's. I pulled a set from an 85 L69 HO Z/28 T5 car. I was stunned when I saw the ratio stamping on the ring gear with a gm part#. So they did exist on the earlier ones, they're just not very common.
Old Mar 31, 2006 | 02:00 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup, I tried to tell that to the lady at the GM parts counter once when I was looking to buy a set of speedo gears, and she wouldn't even look them up for me. She said that GM never put a 3.73 in a 3rd gen period.
I didn't even bother to argue with her since she seemed to think she was all-knowing on the suject. I just chuckled a "whatever" at her and left.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Regal105
Aug 23, 2015 03:45 PM
