T5 measurements - please help!
Old Apr 5, 2006 | 05:30 PM
none's Avatar
Car: '83 T/A
Engine: 355
Transmission: BW T5
Axle/Gears: BW 3.27
Hey, Ok, i'm doing the T5 swap and i have a slight problem: I'm not sure where to cut/drill the hydrolic MS holes, and the hole for the shifter. I'm doing all this while rebuilding the engine, so theres no engine or tranny in the car at the moment.. which makes it good for space.
I bought all the stuff from an already scraped car, so i can't get any measurements off that... so, if anyone has a template they can post, or meassurements it will be more than helpful.
thanks.
Old Apr 5, 2006 | 05:36 PM
The Phantom's Avatar
I am having the same issue, I have been given a picture, stand bye.
Does this help?
Dave
Last edited by The Phantom; Apr 5, 2006 at 05:40 PM. Reason: Automerged Doublepost
Old Apr 5, 2006 | 06:08 PM
none's Avatar
Car: '83 T/A
Engine: 355
Transmission: BW T5
Axle/Gears: BW 3.27
it does thanks. from what i can see pretty much all the flat spot needs to be cut out.
Does anyone have anything a little more technical...
ex. x.x" right from the brake mc or x.x" down away from that.
thanks
Old Apr 5, 2006 | 06:11 PM
If you find out anything more, I would apreciate it if you could let me know.
Thanx
Old Apr 6, 2006 | 06:36 AM
none's Avatar
Car: '83 T/A
Engine: 355
Transmission: BW T5
Axle/Gears: BW 3.27
I will. No, problem.
Does anyone have anything? I think this would help out a lot of people.
Old Apr 6, 2006 | 10:52 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
the search is back up in case it was not noticed, theres much information on this, someone even made a template you can print out for cutting your master cylinder holes
anyways, never thought of doing it this way until just now but if you really need to make sure the holes are going in the right space bolt up the pedal assembly first, the 2 rods on each end connect to the u-bolt on the master cylinder... that will put you dead on for those holes, then you just gotta drill out the big hole in the center
Old Apr 6, 2006 | 02:41 PM
none's Avatar
Car: '83 T/A
Engine: 355
Transmission: BW T5
Axle/Gears: BW 3.27
Thanks: heres what i found..
https://www.thirdgen.org/forums/tran...ht=T5+template
pretty informative.. only thing is i can't see the actaul template pic..
Old Apr 6, 2006 | 06:38 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
go to a JY find a 5-speed car and measure it first hand...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Jul 1, 2018 04:12 PM
AUZ28
Oct 3, 2015 06:28 PM
