findin gears???
findin gears???
hello all!!! i am knew to the forum!!! i am from delmar, delaware!!! i was wondering where i could buy gears, c clip elimanators and a mini spool or even a full spool for my 9 bolt borg warren 7.75 rear!!! i can't find anything and i have been lookin for weeks, it is tickin me off
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Glad to see another DE guy here. I'm from Newark. There's a couple of other guys here too. Spread the word to your 3rd gen buddies.
9-bolt stuff is like hen's teeth. Mostly I've onyl seen used gears avaialble. There were three factrory ratios I believe. The 2.77 is the most common, and then there were 3.45s and one other that was like either a 3.77 or a 3.2-something.
It's a shame parts for these things are so hard to get. It's a good rear tat holds up well to a lot of power, but they just didn't built that many of them.
BTW, if you want a spool you could always weld the side gears to the carrier, but if you street drive the car I would not advise this.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I bought my 3.73 from Randy's ring and pinion. I think with the install kit too it was $300+. Strange offers gears for the 9-bolt. Kinda outrageous in price though.
www.diffsolutions.com carry parts good luck on getting ahold of Miles though.
I've also heard of a few other shops that sell gears and kits. Reindeer racing or something like that. Do some searching and you'll find the urls you need.
Probably Reider Racing, they are a large rearend parts supplier.
Engine: 383 SBC
I believe that was it. I think the Randy's ring and pinion are actual Yukon gears, but I can't remember for sure.
Yes, Randy's Ring & Pinion sells gearsets called Yukon, which they make in house. They are very high quality, and come highly recommended if available. I have built about a dozen rears with then, and never had a lick of difficulty.
Exactly, one of the advantages to the 9-bolt is the bolt in axel retention, just like a Ford 9" This way if an axel breaks the wheel doesn't come flying off, and you might even be able to drive it a short distance (like back to the pits) as long as the bearing holds.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
