tailshaft shatterd?
Old May 27, 2006 | 10:17 AM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
tailshaft shatterd?
has anybody every shatterd the rear tailshaft where the torque arm bolts on?only 40 miles on built 700r4 shatterd the tailshaft broke the driveshaft while cruising at 60mph in 4th gear will post pic. soon
Old May 27, 2006 | 11:13 AM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
was it vibrating at all?
Old May 27, 2006 | 12:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The tailshaft, or the tailshaft housing?
Old May 27, 2006 | 01:35 PM
Shagwell's Avatar
Car: projects.......
? - also, you sure it wasn't that the driveshaft took out the tail-shaft/housing?
Old May 27, 2006 | 01:47 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Zipping the mounting bolts to tight with an impact gun can cause this. Easy to swap out and inexpensive to buy used.
Old May 27, 2006 | 05:28 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Here's a pic
Only around 30 miles on the trans
COMPLETELY DESTROYED
Old May 27, 2006 | 05:31 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
ok, that's not your tail shaft/housing that broke. that's the bellhousing!
that normally happends cause you didn't have the bellhousing bolts torqued correctly.
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I have seen that before. It looks like your problem may be behind the driveshaft. Check pinion angle first.
Old May 27, 2006 | 07:20 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
also broke the tail shaft housing and broke the yoke off the front of drive shaft,rear end is not locked up,could it be internal problem in trans?
Old May 27, 2006 | 07:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I would guess that you'll find Bad Things inside that transmission if you take it apart.
Old May 30, 2006 | 06:03 PM
Shagwell's Avatar
I just inherited one that looked just like that. Had a pump bolt come loose and come in contact with the tc at about 4500rpm on the bottle....the ribs in the TC grabbed the bolt and...well, it looks just like yours. Suprisingly, nothing internal was hurt.
- As for your's, either a problem was missed before/during assembly, or something is out-of whack.
list of somethings:
- driveshaft balance
- improper driveshaft length
- TC balance
- seriously f'ed u-joint
- bellhousing bolts loose
- TC not properly/fully seated into pump, bellhousing tightened against it
- ? trans internal
bradkeith
Feb 27, 2002 01:37 AM
8Mike9
Sep 29, 2001 10:25 PM
mcconahay37
Sep 3, 2001 05:37 PM
LilJayV10
May 27, 2001 09:43 PM
v6-3.1
Feb 20, 2001 11:49 PM
