rpo code g80
Old Jun 8, 2006 | 11:34 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
rpo code g80
is rpo code g80 ---limites slip diferential, posi-traction a standard option on camaros. acording to a sight i checked it said it was a 100 dollar option. anyway im just curious.
Old Jun 8, 2006 | 11:38 PM
z28b88's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8l V6 MPFI
Transmission: 5-speed
g80 is.... limited slip posi
Old Jun 8, 2006 | 11:39 PM
Engine: 383 HSR EBL
right but is it a standard option is really what im interested in. because according to my rpo's i have a posi 2.73 rear end.
Old Jun 8, 2006 | 11:41 PM
z28b88's Avatar
they probably are but mine came with 3.42 non posi... so i guess it all depends on what engine it came with... not to sure tho
Old Jun 8, 2006 | 11:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What do you mean by "standard option"?
Old Jun 8, 2006 | 11:55 PM
Engine: 383 HSR EBL
standard option is something that is automaticly put on a car or at least thats my understanding.
Old Jun 9, 2006 | 12:00 AM
z28b88's Avatar
im thinkin that it was probably an option at the dealer and if the orginal buyer wanted it then he would request it but like i said it might be based on the engine size.... more power=better rear-end to handle the power
Old Jun 9, 2006 | 12:03 AM
Engine: 383 HSR EBL
true. its the 305 tpi motor not an incredibly powerfull motor with 2.73 rear gear.
Old Jun 9, 2006 | 12:08 AM
z28b88's Avatar
i don't know man...some v-8s are posi some aren't i guess....it could be possible that your rear was swapped in by a previous owner but i don't know how likely that would be but hey anythings possible
Old Jun 9, 2006 | 12:26 AM
Engine: 383 HSR EBL
so true, so true.
Old Jun 10, 2006 | 05:49 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
It was not standard on all Camaro's, but was a required option with other option codes. And since it's listed as a $100 option, it would be an addition to a standard optioned car. A standard option would have no additional cost.
Old Jun 11, 2006 | 09:09 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As 1991L98 states RPO G80 was an extra cost option,in this case $100.It was an upgrade from the standard open rear end differential on all F-Bodies.It was required when you ordered RPO J65(4 wheel disc brakes and this also required ordering a V8 engine if it wasn't standard in the model being ordered).
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
