Transmission Replacement needed.
Old Jun 22, 2006 | 10:15 PM
firefightermike's Avatar
Car: 1991 RS
Engine: Stock 305
Transmission: 700-R4
My 91 RS needs a new transmission. It currently has a 4 speed auto that is original. I would like to know which Transmission I have (400)? Or how do I go about finding this information out.
I would also like to get suggestions on the next step.
-Do I try to get it rebuilt
-Should I go for a reman or new
-What kind of performance upgrades should I look into
Old Jun 22, 2006 | 10:18 PM
Eight4Firebird's Avatar
I don't know much, but I was told something about going under the car and counting the bolts on the tranny will tell you. Mine was either 11 or 16 so I counted...16...and I found out what it was.
Old Jun 22, 2006 | 10:23 PM
Car: 1991 RS
Engine: Stock 305
Thanks! What transmission do you have with the 16 bolts?
Old Jun 22, 2006 | 10:29 PM
I have 700r4 OD
Maybe it wasn't 16? Does that tranny have 16? I forget...now I'm curious, do you know if a 700r4 is 16?
Old Jun 22, 2006 | 10:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
im amused, lol
maybe this will help yall
http://www3.telus.net/cbradley/TransIDChart.JPG
btw if its 4 speed auto then its a 700r4/4L60
big rectangle shaped pan
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
fire fighter, you have a 700R4
What motor is in the car? Planning big HP upgrades?
if not, just get a decent condition junkyard trans. Rebuilding will be expensive, roughly the same cost as new.
Old Jun 22, 2006 | 10:57 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
and dont forget a trusty ol 9" tail th350 would pop right in place with the B&M brackets
Old Jun 23, 2006 | 08:00 PM
Shagwell's Avatar
Car: projects.......
and don't forget you'll then have a steaper 1st(less performance) and no OD(less mpg)..........
Old Jun 23, 2006 | 10:00 PM
Car: 1991 RS
Engine: Stock 305
Thanks everyone
Thanks everyone for all the info!
I plan on rebuilding my 1991 RS from the ground up. So definate HP modifications are in the future. This car won't be used for racing, but I want to build a high quality, powerful, and most important-a car that will last to pass onto the next family generation.
Presently I have an unmodified 305 TBI. This won't last long!
Any suggestions on Transmission setups and aftermarket add-ons that will improve performance and be reliable as well?
Old Jun 23, 2006 | 10:12 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
There are many mods that you can do. Most install a heavy duty reaction shell. Some also beef up the 3-4 clutch pack.Do not be afraid to search. Lots of info in the archives.
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
z28_AJ
Aug 27, 2015 08:59 PM
mizz0313
Aug 12, 2015 06:45 AM
