Will a 700r4 from an 86 work with a 91?
Car: 1991 RS
Engine: Stock 305
Transmission: 700-R4
Will I be able to use a 700-R4 out of a 1986 Camaro in my 1991 Camaro? Ins't there sensor issues or wire modifications.
Car: 92 RS, 87 Formula, 89 IROC, 05 SRT4
Engine: 5.0 TBI, 5.7 TPI, 5.0 TPI
Transmission: 700R4 x2, T-5
Axle/Gears: 2.73, 3.42 posi x2
the only difference is the Vehicle speed sensor, which replaces the speedo cable in the older transmissions... I don't remember if your 86 uses a VSS or a cable, but either way it's an easy swap, and thats the only difference between the two
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get the trans and converter from the 86 as a set.
The 91 you are replacing is a far better rebuild candidate than the 86 as well.
It will work with the above mentioned speedo issue.
later
Jeremy
later
Jeremy
Car: 1991 RS
Engine: Stock 305
Thanks, Jeremy
If I don't have the converter from the 86 can I use the 91's? What's the difference? What should I be looking for or any tips on rebuilding the 91 Trans?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by firefightermike
Thanks, Jeremy
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
is the 91 trans bad?? don't even think about using a converter from a bad trans on a good one, besides it won't fit like mentioned above.
