spohn tourque arm problem
Old Jul 14, 2006 | 02:04 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I have had this problem since the tourque arm went on a year ago. I swapped in a t56 and spohn crossmember and tourque arm all at once and it never was right. The problem is when ever the car is in between load and un load in gears there is a lot of play in the drivetrain somewhere. It sort of rocks violently, and it sounds like something is hitting. I contacted spohn and they stated it was the tranny mount, so I bought theirs to replace my brand new energy suspension mount, it did not help the problem at all. It sounds like its coming from the front, I was thinking maybe motormounts? I have the spec stage 3 clutch so maybe it is what is causing the problem to be so bad. Please help I have 2 weeks untill I go back to the track.
Old Jul 14, 2006 | 03:01 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
is it the torque arm that's mounted to the crossmember? if so i believe it's designed to move forward and backwards. I believe it's called a de-coupled torque arm
Old Jul 26, 2006 | 12:08 AM
irocman7's Avatar
Engine: Forged 383
Its the spohn tourque arm which mounts from the crossmember to the rear end. One question is what are the 4 bolts on the tourqe arm supposed to be tightened to? Theres the two on the front mount and the two on the rear.
Old Jul 26, 2006 | 02:55 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
4 bolts???, where it mounts to the rear end???, only 2 of those holes are used, the other 2 are for the Moser 12 bolt rear, and there is only 1 bolt in the front, the only 4 bolts I can think about on mine are the crossmember bolts....which I just cranked down
Old Jul 27, 2006 | 01:37 PM
irocman7's Avatar
Engine: Forged 383
This is not my torque arm, this is a pic of an ls1 torque arm but it will work. The four bolts I am referring to are bolts abc&d. What are these supposed to be torqued to? Further what is supposed to move on this whole assembly?
Old Jul 27, 2006 | 02:08 PM
Engine: 383
ooooooh.....the only one of those I touched was "A"....and I tightened it to "good 'n' tight", the rest I left alone
Old Jul 27, 2006 | 02:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
tighten A and snug B and for good measure, hit it with the grease gun.
Old Jul 27, 2006 | 02:54 PM
irocman7's Avatar
Engine: Forged 383
Well I believe I torqued down all of them pretty tight, bolt A being really tight. Could this be causing my problem? If so, should I just loosen them up?
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
