Confused
Old Aug 20, 2006 | 11:50 AM
kjvail1204's Avatar
Confused
I'm having some problems with the terminology. Im not getting what the difference is between a stock rear end and a 3 series. I have stock 2.73 gears and im looking to put in 3.73 i have heard you can get them from a 2.8 V6 Chevy Blazer not sure what year but i read its a direct bolt in. Should i just change out the whole rear or try to remove just the gears.
If i get them from a store i need a 3 series so thats where my 3 series question comes from.
Old Aug 20, 2006 | 12:14 PM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
3 series is the carrier not the rear end housing.If you have 2.73 you have a 2 series carrier which means you can only put up to 3.08 ratio.A 3 series will accomidate 3.23 and numerically lower gears like 3.73 4.10 and so on.The s10 rear is a leaf spring rear and wont bolt in so you should buy new.You can buy a ring gear spacer to"convert" your 2 series to a 3 but its not the best way to do it.You will have to buy a posi unit a ring & pinion set and an install kit to do it right.
Old Aug 20, 2006 | 12:17 PM
kjvail1204's Avatar
is there anything i can pull out a 3 series carrier. Id rather try and pull one instead of buying a new unit. But if i have no option i will buy a new one.
Old Aug 20, 2006 | 12:36 PM
quick ones's Avatar
Car: 85 firebird
Transmission: th350
maybe someone on this site has a used one for sale if not you have to check all the 7.5 rear ends in junk yards etc.
Old Aug 20, 2006 | 12:39 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I think I was on the thunder racing site the other day. They sell 3 series gears for 2 series carriers they are strange brand I think.
Old Aug 20, 2006 | 12:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i dont see what the big deal is guys... my car came stock with 2:73 rear ration, i purchased a ring and pinion set from summitracing, richmond gear brand, and the part is availiable for both carrier sets, just check their catalog, both are listed just need to pick the righht one. swapped mine for a 3:73 ratio into stock axle.
part # is (check and make sure) rmg-4900071 193$
i couldnt find the part # for summit but jegs sells complete rear change kits complete with bearings shims gear oil and a video everything you need (minus tools) to swap gears pn for 2 series carrier 836-49-0007-1k
Old Aug 21, 2006 | 11:18 AM
quick ones's Avatar
Car: 85 firebird
Transmission: th350
You guys are correct you can buy a R&P with a thick ring gear to fit the 2 series carrier but kjvail1204 didnt know the difference between stock and 2 or 3 series and I was trying to explain it. I also thought he was upgrading to a posi unit which you cant do buy just buying a gear set I guess I got off the original subject.Good luck with the swap.
Old Aug 21, 2006 | 01:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
stock= factory= any part/component that the factory installed on the vehicle when they built/assembled it,
just to help clear that terminology up a little bit
good luck
Old Aug 21, 2006 | 04:57 PM
kjvail1204's Avatar
thanks so much guys, i saw a swap on horse power tv, they used another chevy as jsut took the rear end out of it. I think im going to go junking soon, and jsut remove my own. thanks again guys
Old Aug 24, 2006 | 02:12 PM
kjvail1204's Avatar
tech artical
hey guys just wanted to let you know i found the answer to my problem, now i jsut have to find a donor balzer
1987 Chevy Camaro Intake, Exhaust & Fuel System
Scroll down a bit i think its near the end
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
