10 BOLT, Something still spinning when stop
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
?? Im gonna be changing my rear end out but,, too make a long story short my rear end is throttle sensitive to whining,. or slowing to a slow er roll it whines ., any way on that note: i notice when i come to an abrupt stop i can almost still hear somthing spining,. what is it ??.. could it be my limited and could this be related to my whining?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
? That's strange... If you jack up the rear end of the car, and spin a tire, can you get the sound? maybe lay under it and spin the wheel, see if you can pinpoint if it's at the wheel(s) or in the pumpkin.
yeah id def sound like its coming from the center pumkin (diff) also what i ment to say was when im rollin and i hear the whinning and i come to an abrupt stop i can hear it still whinning like its spinin and im stoped,.,.what is it??
hmmmm
well when im rollin ill hear the whine then if i stop abruptly and compleatly i can still hear a whine as if somthing is spining ,it goes away about 2or 3 seconds after im stoped,, like it stops spining,.,. note: this does not happin under normal driving conditions just if i stop harder then usual,,but my whining is constant every where i go and is throttle sensitive i let off gas it goes away but soon as i accelerate or come to a slow down it comes back.,., and im wondering could there be somthin in the rear still spining when i stop like that., couldnt be my fuel pump making noise like that when i stop hard could it?
Put the car up on jack stands, with nobody and nothing in front of the car and the front wheels chocked and the stands UNDER THE AXLE TUBES; do whatever it is that makes the noise; see if you can find it.
I can't think of any parts that would tend to do that, to tell you to look at. There's nothing that comes to mind that's welded or otherwise fastened around anything, that could come loose. Pretty strange.
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
could be the fuel pump is being starved for fuel or being restricted somehow cause that soulds like what my car does if i have less than 1/8 tank or 1/4 tank if im beating on the car. like mabe something is swinging infront of the pickup when you are on the brakes hard.
I wouldnt think anything with the Axle/Driveline would cause that cause if it were still moving after you stop you wouldnt get moving in the first place would ya?
