T-5 aggressive shifting issues
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
When shifting aggressively from 1st to 2nd and 2nd to 3rd my car makes a loud THUNK! THUNK! noise. This only started happening a few days ago. I thought perhaps there was a problem with the front suspension, but everything checks out ok. Could my tranny mount be loose/broken? I'll be able to check it tomorrow when I get the car on stands, but in the mean time if anyone has a suggestion I'd be glad to hear it.
Car: 86 iroc 92 rs parts car
Engine: 350 305
Transmission: t5 t5
Axle/Gears: 3:73, 3:08
i would check or replace the torque arm mount if it's stock(older than dirt)also where the thump coming from front middel or rear
I was just driving it and it almost sounds like the tranny is hitting the top of the trans tunnel!
Engine: 350 305
Transmission: t5 t5
get under the car and see if you can see alot of rubber cracking on the tranny and torque arm mounts or soft spot.and if you replace with rubber it will be smoother but if you go with poly it will be stiffer with more thumps but good thumps
Its too dark to check it out tonight. I'll know more tomorrow.
Definitely sounds like the tranny mount. A bad torque arm mount will make a little noise, but a loud thump like the trans hitting the tunnel is almost always a broken trans mount. Replace it with an Energy suspension polyurethane mount. They're well worth the extra money over the rubber ones.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I'll second that! I put one on my 87 Formula and it was the best thing I ever did!
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
if it was the trans mount your stick should jump up and down
i've broken three of them, and the last one sprained my wrist. it broke while i was burning around a corner in second gear at 5000 rpm and i had an iron grip on that stick.
Yeah, I got her up in the air today and confirmed that it is in fact a broken tranny mount. Unfortunately, I have that weird round tranny mount that costs like $300 from the dealer (no one else stocks it) not the $25 one that 99% of GM RWD cars came with.
Here is a pic of the one I have. I grabbed this pic from a post I found after doing a search in this forum (not my picture).
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
, crossmembers are east to come by in the bone yards, all 84-92 will fit...82's and 83's wont Thread Starter
Thanks guys! I was hoping that would be the solution. My local bone yard has several f-bodies most of which are missing their trannies (which will make getting a cross member that much easier!)
Woohoo! Went to the wrecking yard today and scored a cross member with tranny mount from an '86 SC for $14!!! Sure enough, it bolted right in!!! Thanks guys!
Yeah, its the stock one. I'll get the poly one on order real soon, but the rubber one is still better than the broken one!
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
