4l60E VSS help please
Old Feb 15, 2007 | 07:45 PM
84cj7lt1's Avatar
Newb question on your forum...I have a 4l60E that I want to Use with Dana 300 Transfer case. I need to remove the 4 bolt tail housing. My question is: do I need to keep the VSS? What is the exact purpose of the VSS? If it only is used for MPH then I realld dont need it right? Please forgive me but please help.
Old Feb 17, 2007 | 07:10 PM
84cj7lt1's Avatar
bump
Old Feb 17, 2007 | 09:39 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if i'm not mistaken, the only 4L60E's to have a vss in the tail housing were the 2wd models. how are you gonna bolt a transfer case up to this? if you are trying to convert the 2wd tranny to a 4wd tranny, you will need to take it apart to replace the output shaft.
Old Feb 18, 2007 | 12:43 AM
84cj7lt1's Avatar
It is a 2wd version off of a 9C1 caprice. I removed the tail housing, and have a Novak adapter to use in between the tranny and the T case. If the only major thing the VSS is used for is vehicle speed, then I can leave it off. My t case has the gear for my speedo. The LT1 has been rewired and the ECU has been modified.
Old Feb 18, 2007 | 08:04 AM
87zjeff's Avatar
well, if you know the lt1 has been modified to work without the speed sensor, then you shouldn't need it at all if you are gonna be using a cable setup for the speedometer.
Old Feb 18, 2007 | 10:29 PM
84cj7lt1's Avatar
Can you please tell me other purposes for the VSS other than speed?
Old Feb 19, 2007 | 05:01 AM
87zjeff's Avatar
tcc lock-up comes to mind. as far as the motor, i'm not sure on lt1 programming.
Old Feb 19, 2007 | 06:39 PM
84cj7lt1's Avatar
This is kinda a big pain in the ***, building my jeep. Should have gone with a plain ol 350 and 700R4.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
