700R4 just dumped ALL its oil
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
2 months ago a garage swapped my knackered 700R4 for a good box that i had laying around ( in my '87 camaro ). The car was taken out yesterday for the first time since the swap and for an hour everything was fine then i saw smoke pouring from the sides of the car so i pulled over as soon as i could . By the time i had pulled over (200 yards ) i had lost all gears and there was a huge amount of transmission oil under the car as well as a long trail behind me.
I looked underneath and could see oil all around the passenger side and smeared around the exhaust , hence the smoke ,
The car now will not select any gears due to the lack of fluid. Any idea what it could be ?? i know the mechanic changed the front and rear seal but i'm wondering if he put them in right or wether he cracked a trans cooler pipe ?? its going ont he ramp tomorrow but i'm sooo p*ssed at the fact it could mean a rebuild
Any thought guys
Any thought guys
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Losing it all at speed is rough man. I feel for you. I can't even imagine what was going on inside the trans as it quickly lost fluid but I know it isn't good.
There are only a few places you could lose fluid that quickly:
1. trans cooler lines. If they popped, there ya go. Its easy enough to think you got em in - especially after a few minutes of swearing at em - when you really only crossthreaded it.
2. Big honkin hole in the pan, as if you ran over something big. Loose bolts wouldn't do this, the pan holds at least 5 quarts, and to think that more than half the bolts came out all at once is ludicrous.
3. Rear end - but the driveshaft would have had to come out. It only sort of drizzles out and not all of it would be gone either.
4. Sudden giant hole in the TC. Again ludicrous as you'd feel it first, those things are solid.
5. Front seal is possible, but not very likely - the TC wouldn't go back on if it wasn't perfect.
6. TV, Speedo, Vent aren't options. Those holes aren't under pressure and don't explain the amount of fluid.
I'm gonna put my money on #1.
Engine: 350 L98
Thanks for the input
My mechanic dropped the box today to find the trans cooler lines in perfect condition and the front seal in good condition
I rang and spoke to someone who knew a bit about the 700R4 box and he said it could be the bush behind the front seal as they can wear out and cause to much pressure on the front seal ????
does that sound about ringht ?
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Sometimes the pressure pushes the bushing out. There is a mod to the earlier pumps to help prevent this. I always lock tite the new front pump bushings in on a rebuild.
They also make a teflon coated pront pump bushing. I recommend using it next go around.
Engine: 350 L98
Well as i said the front bushes were worn and so they were replaced and the tranny was bolted up yesterday morning.
The leak is now sorted but the transmission wont select 3rd now ???? I'm wondering that when i lost the fluid and kept going to find a safe place to stop that maybe i fried the box ??
I'll whip the governor out tomorrow to see if its got gunk all around it. Could the symptons that i've got now have been caused by loosing the fluid
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The governor typically will not allow an upshift from 1st gear, if the valve is stuck, or the gear is stripped.
Check it though, goos place to start.
If that does not work, a valve may be sticking in the valve body.
Engine: 350 L98
Can i have your honest opinion on this box floorguy. I'm sick of messing with mine and i thinking of buying this box.
https://www.thirdgen.org/forums/engi...eet-strip.html
Craig
Craig
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Tough question to answer solidly. The link in the for sale section takes you to the listing at Summit racing. It does not describe what is actually in the trans. Because I have no 1st hand experience with Hughes products, I cannot answer accurately. Do you have local people that can do a good rebuild of your unit? I would imagine that they are more difficult to find in your neighborhood.
Engine: 350 L98
I've arranged a friend of mine to stick a transmission in the container he is shipping his car in and that will be free so you can see why its far cheaper to go down this route
I just need to be certain the tranny i buy is a good one due to my location
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Wow.
I guess we are luck here in the states. I built one for a friend in spain, and they wanted $4000 US dollars to rebuild his. Another friend in Italy had me do 2 for his car(and a friend) because pricing was similar.
Pro-Built is a forum sponsor and has a great reputation. I bet he can be a huge help. I buy parts from Dana(pro-built) and am very pleased.
I have a corvette forum member in England asking about parts and info. I wonder if he is using 1 of the 3 guys you mention?
Engine: 350 L98
I would put my house on the fact he's using either
GM auto's
Alders automatics
or Penn auto's
They are the only three that can be trusted with a 700R4.
I'll have a look on pro-builts website. I really want to get this thing sorted i've already spent a fortune on two boxes that are now good for nothing.
The March transmssion looks a good box but again i have no idea whether it'll need a rebuild straight off the bat , a lot of miles can be covered in 2.5 years,.
GM auto's
Alders automatics
or Penn auto's
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
