T-5 From a Mustang
Old Apr 10, 2007 | 12:18 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
T-5 From a Mustang
Alright, I dont know if this has been discussed before. And if it was, I didnt search because I have no clue what to even type in.
My friend wrecked his 87 Stang with a 5.0 and T-5. I know GM also called their 5 Speed manual trannies, T-5. My question is , would a T-5 from the stang bolt into a Camaro with a L03? I mean besides the obvious bellhousing swap, but can it be done?
Thanks!
Old Apr 10, 2007 | 12:31 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: T-5 From a Mustang
Nope, Internals are the same, cases are different. Use the SEARCH function, its been covered many of many times.
Old Apr 11, 2007 | 01:40 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I asked that same question
Still havent found the right t5....=(
Old Apr 11, 2007 | 02:48 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i've seen a few posts on corvetteforums.com where they use them in C3's with a small block chevy, i think you need adapters and so on, but i believe they get them to work?
Old Apr 12, 2007 | 10:32 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Are they stronger? Could you use the internals in a GM WC T-5? Would it be strong enough to put behind a 400hp 383?
Old Apr 12, 2007 | 11:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
On the GM T5s, the internals aren't the problem. Its the case itself - its a poor design that flexes under a heavy load (ie. powerful motor, sticky tires). When that happens, the geometry inside goes all to hell and then things start to break.
Old Apr 12, 2007 | 11:45 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
HELL NO! It wasn't strong enough for a STOCK 220 hp 350. The WC T5 is only rated at 300 ft lbs torque ,max!! You will blow the thing so bad with that motor, I would be worried about losing a leg when parts come through the floor.
Old Apr 13, 2007 | 05:29 AM
avitet's Avatar
yes McLeod makes a bell so you can adapt a ford t-5 to a chevy small block
Old Apr 14, 2007 | 02:55 PM
Shagwell's Avatar
Car: projects.......
So now you've spent outrageous $ to get it bolted in and you still need a different clutch plate to fit the lesser splines, and you have to eliminate your radio to bolt the shifter on(which will now sit in the dash).
Get a GM trans.
As for power, there's a reason GM never put one behind a 350. They'll take more than many people think when driven properly, but they will eventually break.
PurelyPMD
May 5, 2016 04:57 PM
ndndndnd
Sep 28, 2015 08:00 AM
okfoz
Sep 22, 2015 03:37 PM
DARKmj16
Sep 9, 2015 04:07 PM
