Car: 1986 Iroc Z
Engine: 5.0 TPI
I have a question. Can you take a 3rd gen 305 and put it into a 86 Firebird?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Engine Swap
its a checy small block, so yes, if the car was a v8 it will bolt right in, if not you probably need motormounts
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Car: 86 Trans Am
Re: Engine Swap
a small block chevy has the fuel pump boss on the passenger side, if you have an electric pump, the line may be on the wrong side, but it can be made to work
Axle/Gears: 3.23's
Re: Engine Swap
/agree itll bolt in physiclly in anything oem with a sbc, But there may be minor alterations u may need to do to get it to run/drive correctly
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Engine Swap
uhh, that would be passenger side boss for the mechanical fuel pump.
But yea, another 305 into a 3rd gen f-body is the simplest swap there is. Not really transmission related though is it?
theshackle
Mar 5, 2017 06:37 PM
