700r4 tranny problems
Old Apr 16, 2007 | 07:18 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
My 91 RS is not shifting properly. it revs up way too high then launches forward. is my tranny going bad? do i need to adjust something? i checked the tranny fluid and its good. I never let it run low. Any ideas?
Thank you!
Old Apr 16, 2007 | 11:33 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Re: 700r4 tranny problems
what do you mean by revs up real high and lurches forward. is this from a stand still. or does it just rev high in normal driving and then slam into gear?
If it is the first where it revs and then slams into gear from a stop and pushes you forward, tranny rebuild time.. it basically is building up preassure and then when it has enough it engages... few different causes. none of them nice.
2nd one. could be a TV cable misadjustment, or if that is adjusted right and properly, then chances are the trans is going out then too...
Quick question though.. Is this on the stock engine. or have you put a different fuel delivery on it like say a holley carb?
Old Apr 18, 2007 | 10:07 AM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
Mine shifts hard after I put my holley carb on. At first when the motor was cold, the tires would cirp when shifting but that went away. It still shifts hard. I removed the vaccum for the tranny and it shifted normal again, but I hooked it back up.
Old Apr 18, 2007 | 10:34 AM
92green3RdGen's Avatar
yep mine is doing the exact same but when i put into drive from neutral it slams into gear...how much is it to rebuild the tranny?
Last edited by 92green3RdGen; Apr 18, 2007 at 10:35 AM. Reason: Automerged Doublepost
Old Apr 18, 2007 | 02:10 PM
transamkid1985's Avatar
Car: 1985 pontiac trans am
Engine: sbc 355 with comp cam and promag ro
Transmission: 700r4 with 2500 stall
Axle/Gears: stock 9 bolt for now.
i just took mine to get rebuilt and it cost me $1200 parts and labor. mine was doing the same thing then the transmission just went out on my way to work i still had reverse so i said oh well and backed it all the way to my house if i were you i would get it fixed as soon as possible or you might be doing what i did to get to your house.
Old Apr 18, 2007 | 07:19 PM
Car: 91 Camaro RS
Ouch I hope you weren't too far from home, that had to suck.
Old Apr 18, 2007 | 07:32 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
does it rock the whole car when u do that?
i had that same issue and it turned out to be a broken trans mount thats it, so check that out first
Old Apr 18, 2007 | 07:34 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Im gonna guess it is a TV Cable.
Old Apr 20, 2007 | 12:41 AM
just got mine out of the shop man am i happy now im ready for my engine swap
Old Apr 20, 2007 | 10:15 AM
nope i checked the mounts but i still need to check the tv cable
Old Apr 20, 2007 | 03:47 PM
with the slamming into gear it could most definitely be the TV cable not adjusted right or not having the right geometry with a holley carb in place. You need a few parts like the 20-121 bracket. without that little bracket (or the one for 700r4.com) you will burn the trans up pretty quick (few thousand miles at most,) Just because it is hooked up to the carb without that it is really pulling it out of wack and can not be adjusted. Pretty common error with that carb I guess. people just throw them on and try to go.. with a manual car you can. but not with the 700r4 trans.
Old Apr 22, 2007 | 11:58 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
I am having a problem kind of like this one. My transmission revs up extreamly high between shifts about 6,000 rpm but thats only when I am at WOT if im driving normal its fine. Do I need to adjust the TV cable and if so how do I do it?
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
