lockup connector...
Old May 8, 2007 | 04:51 PM
j dezzy's Avatar
Car: 87 TA
lockup connector...
I'm thinking about picking up another 3rd gen. a guy down the road from me has a 92 bird in great condition and only wants $600...but it has no trans. Although, I have a th350 trans just lying around. but it doesn't have a connector for the lockup that the original 700r4 had...do I even need this? Also, will a 700r4 tailshaft work with a th350? thanks
Old May 9, 2007 | 10:19 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: lockup connector...
I dont think it makes a difference if you dont have the connector hooked up to anything. It may give you a couuple codes but i dont see how it could affect anything else.
Old May 9, 2007 | 01:04 PM
j dezzy's Avatar
Car: 87 TA
awesome. I'll be getting rid of the computer with it anyways. now, does anyone know if the 700r4 tailshaft will work with the th350 trans?
Old May 9, 2007 | 01:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not directly.
Old May 9, 2007 | 01:37 PM
j dezzy's Avatar
Car: 87 TA
Originally Posted by Apeiron
Not directly.
What do you mean not directly?
I've never used a 350 trans in a 3rd gen, only the 700. All I've got is a 700r4 tailshaft, and a 350 trans. If that tailshaft won't work with the 350 I'm not going digging through junkyards for one that will fit.
Old May 9, 2007 | 01:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you wanted to tear the whole transmission apart to put a 700R4 tailshaft into the 350 you could, and somewhere there's an adapter available for the tailshaft housing.
Old May 9, 2007 | 02:27 PM
brutalform's Avatar
I dont think codes will be an issue, except for the VSS.
Old May 9, 2007 | 02:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The VSS on his 84 is cable driven, so no issues there.
Old May 9, 2007 | 03:14 PM
brutalform's Avatar
Old May 9, 2007 | 03:58 PM
j dezzy's Avatar
Car: 87 TA
The 350 trans isn't from my 84. my 84 has a t5. the th350 is from a 78 pickup truck. and I've already got the tailshaft from the old 700r4, the current owner already took it off. but we weren't sure if it would bolt up to my th350 or if we would need something else. ie, adapter.
Old May 9, 2007 | 04:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you talking about the tailshaft, or the tailshaft housing?
Old May 9, 2007 | 04:10 PM
j dezzy's Avatar
Car: 87 TA
sorry for the mix up. tailshaft housing.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
