Killed the 700r4 last nite, any ideas?
Old May 10, 2007 | 02:50 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Ran a 10.76 at 127 with a 1.60 60ft in the gta. Drove the car home(about 60 miles) and while I was pulling into the garage, it stopped moving and puked tranny fluid all over the garage floor. Drove home just fine. I haven't jacked it up to look at it yet, but it wouldn't move in drive or OD, I had to push it in the garage.
I ran the car with the gear selector in D. Does anyone have any ideas what broke?
The tranny was built by a guy who knows these trannies and 200r4's, and it has all the goodies, beast sun shell, 5 gear planateries, billet servo, etc. Car is a 383 miniram, 3500 yank stall, 3.73 gear, 150 shot of nitrous on et streets. I want to stay with an overdrive tranny if I can.
Old May 10, 2007 | 09:39 PM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Re: Killed the 700r4 last nite, any ideas?
what about a th400, and a gear splitter from gear vendors? it would suppoprt your horsepower, give you more gearing, and allow you to keep an overdrive.
Old May 10, 2007 | 09:52 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
First off, congrats on the 10.76 pass! I bet that was the only one you got to make.
I would drop the pan and see what's in there. I'd tell ya to try Bernard but I think he's out of the trans business. Hopefully Dana from Probuilt witll have some input. May not be that serious.
Old May 10, 2007 | 11:36 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well, at least you got a decent pass out of it!
This sounds almost like the TH400 in my buddys mudbogger, everytime hes out in the mud working it real hard it will puke out a few litres of oil. Fill it up and its good to go again!
Old May 11, 2007 | 01:13 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Since I drove it home for an hour and it was fine, I'm thinking the tranny is good, and it just kicked out the rear output shaft seal. I'll jack it up tonite and see where the fluid came from, hopefully it's just the seal!
I've got more juice to hit it with and some turbo headers in the garage so this tranny is gonna catch some future hell.
Old May 12, 2007 | 12:02 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
haha, your going to blow that car apart!!!
Old May 12, 2007 | 07:27 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
that happened to me once... drove the car home and got out the next morning and car wouldnt budge in gear and I noticed alot of trans fluid! turned out one of the trans lines got a pin hole in it and leaked everywhere...
Old May 12, 2007 | 09:57 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
False alarm, the governor cover popped off and was laying on the crossmember. I pushed it back on and filled it with fluid and it's all good. I will have to find some way to seal that cover or clamp it somehow.
camaro11j
Sep 19, 2018 08:49 AM
Americanmouse
Sep 7, 2015 12:10 PM
spaigo
Aug 21, 2015 07:46 PM
formula_novice
Aug 18, 2015 08:48 PM
