Need help ID ing axle in an 82 Z-28
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
How can I tell what gear ratio axle is in the car and if it has posi traction?
Is there a tag or number on the axle if it is still stock?
I think everything is stock but we were told it has posi and better gears, Id like to know for sure.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need help ID ing axle in an 82 Z-28
The only way to know for absolute sure is to take the cover off and look.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Assuming it's still stock and the internals are still stock, you have 2 other options. An RPO code will tell you what's in the diff providing the RPO sheet is still readable. Also stamped on the front of the passenger side axle tube near the center section will be a code. This is normally very hard to read.
If however the rear cover hasn't been off in 25 years, It's a good time to change the diff oil and while the cover is off, have a look inside to see what's in it.
Car: '91 RS
Engine: 5.0L gross *** tbi
look at the info on this site.....
and do a couple burnouts if both wheels spin u got posi...it'll slide one way or the other if not you'll jus sit there (or open the diff to be sure lol)
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[QUOTE=TBITrucker;3406176]How can I tell what gear ratio axle is in the car and if it has posi traction?/QUOTE]
Here's how to determinne what ratio the rear is (numbers are stamped on the ring and pinion):
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
_________
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
_________
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Looking at the diff case from the rear, there will be a tag on the right side, which I think says "limited slip". On my car it is mounted about the 4 o'clock positon under one of the bolts. It ia maybe 1/2 inch wide by about 1-1/2 inches long. On the gear ratios, it is probably best to remove the conver an count. I have not been able to find the code on the axle, due to the rust cover.
If you have rear drum brakes, there are 5 possible ratios, 2.73, 2.93, 3.08, 3.23, and 3.42. If you have rear disk brakes there are only 4 ratios available, 2.73, 2.93, 3.08, and 3.23.
JamesC is missing 41 : 14 2.93 in his list and 41 : 11 3.73 was not available in 1982.
Dave
Dave
Interesting. I've never heard of the 2:93 (hey, I don't get out much). What years might have had that gear set?
JamesC
JamesC
AFAIK that was a CFI combo only, so it would have been available only in 82 & maybe 83.... 41 & 14
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
here is a list of several calculators. there is one in here that will take your rpm,speed,and tire height and give you the gear ratio. you have to use the 1:1 gear in the trans to figure off of. third for auto, fourth for manual----but you already know that dont ya
http://www.baileytondragstrip.com/in.../Fastmath.html
Speaking of getting out and about.....you have any plans to visit the SuperChevy show in KC (Aug 17-19) or the Camaro Club of KC Midwest Camaro Fest Aug 25th?????
Dave
JamesC
