borg warner or not???
Old Aug 15, 2007 | 01:30 PM
hardroc's Avatar
hey guys i have a 1990 iroc l98 factory car with a t56 i really dont know what my rearend is it is stamped borg warner. but in 90 didnt they stop using borg warner?? anyways to get to the point i have installed an t56 in my car and i need a gear bad i want a 410 or 411. does anyone know what size my rearend is and can i buy a ring and pinion? what size do i need or do i need to find a 10 bolt out of a v6 car and build it to my needs . some help would be appreicated
Old Aug 15, 2007 | 01:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: borg warner or not???
Count the bolts on the cover.
Old Aug 15, 2007 | 01:34 PM
hardroc's Avatar
what will that tell me
thanx
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Whether you have a 9 bolt or a 10 bolt rear.
Old Aug 16, 2007 | 12:15 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
They did put the 9 bolt in a few of the 90 car until they used up the remaining stock. If you have a 9 bolt then you gear selection is basically limited to stock gear or 3.70. It's very difficult to locate anything higher than a 3.70.
Old Aug 21, 2007 | 03:43 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
my '90 IROC with L98 5.7L has the 9-bolt Borg-Warner rear-end with disc brakes. the tag on the 9-bolt diff cover indicates 3.27 gears.
ring gear size is 7.75"
I think they were used in 1991 also.
Old Aug 21, 2007 | 10:33 AM
hardroc's Avatar
so my ring gear is 7.75 in size i looked at my i.d tag and it says i have 3.27.i want a 4.10 for my car with my t56 so i geuss i need to be finding a 10 bolt ..
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Vojtush31
Oct 11, 2015 01:07 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
scottmoyer
Sep 7, 2015 07:06 PM
