700r4 does not hold 1st
Old Aug 20, 2007 | 09:49 PM
LawstCawz's Avatar
700r4 shifts out of 1st gear at ~4500rpm, even when shifter is held in 1. Sometimes on the 2-3 shift, I need to let off WOT for a second to let it shift. It has had this problem ever since the rebuild and I cannot figure it out. In a '91 Firebird with ~500hp 383. Any help is welcome, thanks.
Old Aug 21, 2007 | 07:32 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: 700r4 does not hold 1st
Try giving Dana at Pro Built Automatics a call, or, www.700r4l60e.com.
Bill
Old Aug 21, 2007 | 04:03 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Install a larger lo/rev boost valve.
Old Aug 28, 2007 | 06:49 PM
LawstCawz's Avatar
looks like i'll be trying the boost valve, will post an update after the swap, thanks.
Old Aug 29, 2007 | 12:50 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Link doesnt work. Mide did similar too after a rebuild. I expressed that I wanted the holding of any gear too. They just dont pay attention it seems. Just throwing trannys together and getting the money. And since you have a Hi-Po car, you get the 90 day warranty. **** on that!! I dont abuse my equipment and anyone just looking at my vehicles know how they are cared for. Its just a scam! Im good at alot of technical things, but have never gotten a chance to try my hand in the auto tranny area. I think Im going to do my own from now on. I figure I can f*ck it up myself for alot cheaper. =)
Old Sep 1, 2007 | 10:12 AM
Burnout91's Avatar
Engine: Modded L98
I corrected the link to Pro Built.
I think the phone number is 909.795.1876.
Bill
Old Sep 1, 2007 | 08:01 PM
performabuilt's Avatar
The 700r4 will overide manual low at high RPM and shift , You can only correct this with a trango 2-3 kit. Some other shift kits may address it to , But you may actually fair better with a govenor kit to raise your WOT auto shift points.
Old Sep 1, 2007 | 08:55 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
junior419
Apr 7, 2025 11:35 AM
db057
Apr 28, 2019 07:45 AM
HikoriYami
Sep 21, 2015 07:11 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
scottmoyer
Sep 7, 2015 07:06 PM
