Shift points too high?
Old Sep 18, 2007 | 01:53 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
My stock LB9 700R4 car WOT 2-3 shifts at 5800 Is this too high? I don't think the stock TPI would be making power anywhere past 4800...How do I adjust this without getting too serious w/ the tranny? Thanks in advance
Old Sep 18, 2007 | 02:02 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: Shift points too high?
My '86 LB9 shifts from 1-2 at about 6500 RPM, and generally about the same from 2-3 (a little lower). What I do is when you feel it hitting peak power, let off the gas a little bit, which causes it to shift, then go back to flooring it.
Old Sep 18, 2007 | 02:13 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Yeah I have done that a few times just to see how it would work out BUT it just seems like you are loosing too much power after you let off. A properly set up transmission should shift at the right RPM's for the engine at WOT. I think I might just need to adjust my T.V. cable??
Old Sep 18, 2007 | 02:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd probably need to set up the governor.
Old Sep 18, 2007 | 02:23 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Im not disputing this but I don't think the tranny has ever been touched internally. Can this come out of adjustment by itself/wear or what?
Old Sep 18, 2007 | 04:25 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
You're probably going to want to test the tac. My car shifts at 5500 through all the gears. But when I hook up my laptop, it's really shifting at 5000 rpm through all the gears.
When driving around my tac is almost dead on accurate, but at about 5000 rpm it is off. Some are worse than others.
Old Sep 18, 2007 | 04:31 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Wow I never even thought of that. I do remember when I last hooked up my autoxray it was off a little at lower RPM's but i never really checked up high. Thanks I will check that out also!
Old Sep 18, 2007 | 06:24 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If that is not it try a cam that will allow you to rev that high to match your transmission shift points.
Old Sep 18, 2007 | 08:20 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
It's The crappy TPI that doesn't flow lol
Old Sep 19, 2007 | 11:07 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
anyone else?
Old Sep 19, 2007 | 11:46 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
X2 on the governor. The weight and springs can stick or bind even break. The gear could be worn it is only plastic.
As IROC said verify your tach make sure the RPM where it is actually shifting.
You don't want to adjust the TV cable to adjust shift points mean and nasty things could happen the the frictions.
Azrael91966669
25
Jun 20, 2017 04:04 AM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
