converter lockup delay
Old Oct 2, 2007 | 08:38 AM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
I have a 700r4 that will not lock the converter untill the trans gets above 100 degrees.After that lt works great. Is there a temp switch in the trans?
Old Oct 2, 2007 | 11:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: converter lockup delay
That function is usually in the ECM. Some 700r4's have a temperature switch in the pan. This usually forces the TCC to lock once the trans starts to overheat.
RBob.
Old Oct 2, 2007 | 11:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No temperature switch in a stock F body 700R4.
Old Oct 2, 2007 | 11:46 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Never seen a temp switch in the tranny, might be in some though, but normally the ECM will trigger the converter when the engine gets to about 150 degrees. Probably some variation on different year cars with that.
Old Oct 2, 2007 | 06:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is a broad statement to make. There are 3rd gen f-body's with 700r4's that have a temperature switch. Which locks the converter during overheat conditions.
RBob.
Old Oct 2, 2007 | 07:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've never seen a wiring diagram for a stock thirdgen 700R4 that included one. No listing for any temperature switches in the P&I.M., either.
Other cars, yes. My 4L60 from a 93 Caprice has one.
Old Oct 3, 2007 | 07:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
1992 Camaro FSH, section Automatic Transmission Diagnosis, page 4L60-43, bottom diagram, type 18, model FB.
That is the stock transmission in my '92. Having installed a Trans-go kit along with replacing the TCC soleniod and associated wiring harness, I can atest that there is a temperature switch.
RBob.
Old Oct 3, 2007 | 09:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Interesting... I found it in the PIM, but not where I would have expected. 4.054 group, P/N 8673634, starting in 1990 for 3.1L and 5.0L, and in 1991 for all 700R4s.
Ok, then, nevermind anything I said about temperature switches.
Old Oct 3, 2007 | 10:46 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Mod wars!
I love it!
Seriously though, what's the purpose of having the tranny get to a certain emp before it will lock up (or not).
Old Oct 3, 2007 | 10:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The temperature switch will force a lock-up if the transmission fluid temperature gets too hot, in case the ECM doesn't for some reason.
The ECM will prevent a lock-up until the engine coolant temperature reaches a minimum temperature.
FormulasOnly
Jul 23, 2018 08:47 AM
2012sergen11
Oct 13, 2015 07:38 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
