T5 FAQ - Everything we know about the T5
Old Nov 29, 2015 | 12:50 AM
  #351
Carystone92's Avatar
Car: 1992 CAMARO Z28
Axle/Gears: 3.08
Re: T5 FAQ - Everything we know about the T5
Hey guys, just joined the site today, wasn't really sure where or how to post haha, but this is my car, with the T5, figured this would be an appropriate thread, future plans are 5.3 LM7 with the t56. 240k miles tho!! Haha, anyways let me know what you guys think.
Old Feb 5, 2016 | 04:43 PM
  #352
gofast50t5411's Avatar
what pilot bearing should i use 14spline t5 to 92 lo3 305 last part needed part # thanks
Old Feb 8, 2016 | 03:10 PM
  #353
Anton Camaro's Avatar
Car: Chevy Camaro '84
Engine: 355 SBC
Transmission: T-5 BorgWerner
Hey guys, I'm wondering if anyone can tell me the lenght of the 3rd gen T5 V8 bellhousing is?
(etc. the distance from where it bolts onto the engine and to the transmission it's self)
I'm merging a V6 4th gen bellhousing and a 350 auto transmission housing together so i can fit my WC T5 to my 350/383 engine.
The reason for the 350 housing is that i only have a 168 t. flywheel with the 400 weights and the customs here in Iceland from the states is ridiculous.
I appologize for my bad english, after all I'm from Iceland
Ps. it would be awesome if measurements would be in centimeters or millimeters
Old May 30, 2016 | 12:57 PM
  #354
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Quick question, need answer ASAP...
Does the tail housing from a WC work in a NWC? For some reason I can get a WC cheaper on eBay than a NWC and I need one NOW...
Old Jun 1, 2016 | 04:59 AM
  #355
Pat Hall's Avatar
Yeah, far as I know, there shouldn't be any difference on the tail housing between WC and NWC T-5's.
Old Jun 1, 2016 | 05:03 AM
  #356
Pat Hall's Avatar
I know this reply is a bit late, but both the V6 and V8 input shafts should use the same pilot bearing.
Old Jun 1, 2016 | 09:01 AM
  #357
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
If I remember correctly the counter shaft bearing pocket is different on the WC Tail and is not interchangeable
Old Jun 1, 2016 | 09:47 AM
  #358
big gear head's Avatar
The WC and NWC use different bearings on the counter shaft, so the tail housing is probably different.
Old Jan 2, 2017 | 09:43 PM
  #359
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Old thread but I'm posting to clear up the WC verses NWC housing differences and can they be interchanged.
The difference is in the thrust surface for the counter shaft thrust bearing. They can't be swapped straight across.
The WC has a flat surface as in the first pic, and the NWC has a recess. I'm buying and selling S10 T5's now and have run up against this. The NWC tail can be modified by cutting the thrust surface deeper to work on a WC trans. I have done this because several customers have bought S10 NWC tail housings for me to modify to cable drive, but they have a WC trans and didn't know the difference in the two.
So bottom line when your buying a difference tail housing, make sure they match.
Attached Thumbnails T5 FAQ - Everything we know about the T5-20170102_192214.jpg   T5 FAQ - Everything we know about the T5-20170102_192147.jpg
Old Jan 15, 2017 | 08:47 PM
  #360
Billybig7's Avatar
How do I tell if I have a t5 or 700r4 transmission in my 86 iroc? Is there a rpo code telling me?
Old Jan 15, 2017 | 09:06 PM
  #361
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
T-5 = manual, 700R4 = automatic.
JamesC
Old Jan 15, 2017 | 10:17 PM
  #362
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
? Manual is t5 auto is 700r4
Old Oct 21, 2017 | 10:08 PM
  #363
mcbitchman's Avatar
Car: 84 s/e, 94 must conv, 66 must
Engine: 2.8 v6
Transmission: 5 speed manual
Axle/Gears: 3.42 posi just chngd from 3.73
ok so everything I see on my trans says it's a w/c by the bearing being a Timken, the numbers on the tag being 1352-197, the stick on tag being 1352-197 yet on the shifter tower there is the numbers 13-52-066-923 and R5 and on the trans body in kinda script lettering Basic 2A..... what is up w/ that? I need to change out the oil to atf if it's a w/c it is in a 84 SE, so I would think originally it had the t5 and then it got changed out to the w/c ,,, and like I said being that I thought it was a t5 I put gear oil in it..... hmmmm. never did trust those tags in that anyone could stick one on and.... oh one other thing as I understand it the bearing is Timken for the w/c and not marked on the reg t5... correct me if I'm wrong here. replacing the clutch which the center of the clutch plate broke free from the friction surface outer.... never seen that before.... thanks for the excellent thread..... ok so how does one go about making about four hundred horse out of the 2.8... lol
Old Oct 24, 2017 | 03:41 AM
  #364
Pat Hall's Avatar
The 13-52-066-923 number just refers to the part # for the transmission case, that's all. Have no idea what R5 refers to, but yeah, going off the 1352-197 number, you've definitely got a WC T5 trans.
Old Jan 16, 2018 | 09:24 PM
  #365
2.5gencammy's Avatar
I actually have a T5 behind a 79 camaro... hence why my username is 2.5 lol. But anyway, I'm tired of my mechanical linkage, would like to go hydraulic and I was curious to see if there were any years of T5 camaro that got a hydraulic clutch, and where it sat on the bellhousing.
Old Jan 16, 2018 | 09:46 PM
  #366
midias's Avatar
84-92 all the same bolt pattern and hydraulic
Old Jan 17, 2018 | 09:54 AM
  #367
alloy's Avatar
Car: 87 IROC-Z28
Madias is correct, and to add to what he said the transmission sits at as I recall is a 17 degree slant to the left. The stock shifter is angled to compensate for this.
I have a couple of shifters I'll give you, and have a bell housing, but no clutch fork I'd sell.
Old Feb 9, 2018 | 08:42 AM
  #368
Dhenny's Avatar
I have a 1984 Camaro V6 transmission that is like to consider changing the 5th gear on. Is there a reference out there for NWC tooth counts?
i have searched a lot with google and no success. Could be good to record that on here.
Originally Posted by iroc_zz
In case you want to crunch the numbers yourself here are the tooth counts. Keep in mind these are just for the GM world class transmissions, I can look up the non world class transmissions if anyone wants to know.
For the V6,
Input shaft gear - 21 teeth
front counter shaft gear - 37 teeth
5th countershaft gear - 53 teeth
5th mainshaft gear - 23 teeth
for the V8 with the .63 5th gear
Input shaft gear - 24 teeth
front counter shaft gear - 31 teeth
5th countershaft gear - 51 teeth
5th mainshaft gear - 25 teeth
for the V8 with the .73 5th gear
5th countershaft gear - 55 teeth
5th mainshaft gear - 31 teeth
Old Oct 17, 2018 | 05:34 PM
  #369
Nelz's Avatar
Here is a an awesome rebuild video from Eric the Car Guy on complete teardown and rebuild of a T5 along with Paul Cangialosi from www.5speeds.com What's interesting to note is that Paul is the original inventor of the cluster support plate and he shows how the counter shaft wobbles on the stock plate and why he built it from Steel originally. There's also a little hack that he shows which is to grind flats on the revers shaft to make it shift better and he also points out the weakness in the shift fingers.
Check it out. Part 1 below.
Old Nov 15, 2018 | 01:06 PM
  #370
So I've got an odd one, I have a T-5 in a second gen Camaro, and I run a modified 2nd gen mechanical linkage to work with the T-5 mechanical fork, as the T-5 is probably out of an 83 camaro. (not sure on that one) I recently built a one piece rear main motor (vortec, to be specific) and I was sort of confused about which clutch to use. I will be running a flywheel for a 91 Camaro, to accomodate for the balance and difference in crank rears. I've been leaning towards grabbing a clutch for a 91 camaro as well, but I wasn't sure if that would work with the mechanical fork. Do you suppose the mechanical release would work just fine with a clutch for a hydraulic throwout?
Old Nov 15, 2018 | 02:20 PM
  #371
chevytech88's Avatar
Car: 88 Camaro Silver and Black
Engine: 350 4bbl.
Transmission: World Class T-5
Axle/Gears: 3.42 with eaton posi unit
82-92 Camaros didnt come with hydraulic throwout bearings, 82 was a 4 spd cable clutch, 83 was a cable clutch t5, and 84 to 92 is hydraulic clutch pedal master and slave cylinders but thats it, as for your fork if itd the same diameter as the t5 one where it holds the throwout bearing than go with a clutch kit for an t5 V8 camaro, i like the centerforce stage 2 clutch myself.
Old Nov 15, 2018 | 06:28 PM
  #372
Sweet! That's exactly what I needed to know!
Old Apr 10, 2019 | 08:00 PM
  #373
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Does anyone know where I can find the clip that holds the reverse/5th gear lever onto it's stud? I can't seem to find one anywhere.
Old May 4, 2020 | 07:22 PM
  #374
blackngoldz28's Avatar
Car: '83 Z28
Engine: stock L69 305 H.O.
Transmission: stock NWC T5
Thanks for adding this. I'm just getting into tranny work on my '83 Z28 and the owner's manual says 5w-20 (same as the motor). I haven't had any problems yet. I'd use conventional and avoid any potential problems from synthetic leaving a residue.
All the people on all these forums saying "ATF in EVERYTHING" or "80w-90 in EVERYTHING" were making me feel crazy.
Old May 25, 2020 | 01:07 AM
  #375
Nelz's Avatar
Found a video of how to check the end play of a T5 on the input shaft just in case anyone needs to know how to do it.
Old May 25, 2020 | 02:06 AM
  #376
Nelz's Avatar
More facts about the T5.
According to Tremec, the shift capability of the following transmissions are:
T5-6700 RPM
TKO-6200 RPM
T56 Magnum-7500RPM+
Magnum XL-7500RPM+
From pg. 7.
https://www.tremec.com/anexos/File/T...erformance.pdf
Although the T5 Installation Tips document does say do not try and shift the T5 after 6500 RPM. https://tremec.com/lit_oem.php
Old Aug 13, 2024 | 10:51 PM
  #377
TorreZ28's Avatar
I did a swap from automatic to a T5 5 speed and I am trying to get my speedometer working.
Currently on the T5 I have a mechanical sending unit:
And the stock wiring from the car came with this connector:
I've seen some other threads that say you can just slap one of these in there and hook it up: Part #: 10456087
But before buying I just wanted to confirm this will work.
Are there any other options?
Will this fix my odometer as well?
Thanks for the help!
My Car: 1990 Camaro IROC-Z 5.0
Transmission out of a 1992 Camaro RS
Old Aug 13, 2024 | 11:13 PM
  #378
midias's Avatar
I just went through this on my friend's car here is a thread. The box was nice because it allowed me to change to his rear end gear ratio without having to change the gears in the transmission for the speedometer. It should also make your odometer work
https://www.thirdgen.org/forums/tran...-am-700r4.html
Old Aug 13, 2024 | 11:32 PM
  #379
TorreZ28's Avatar
Thanks for the info...
Saw this post from a few months ago.
Does it work? and are you looking to sell this sensor?
That's assuming you still have it.
Originally Posted by midias
Lol look what I found in my parts bin
Old Aug 13, 2024 | 11:39 PM
  #380
TorreZ28's Avatar
Old Aug 14, 2024 | 10:12 AM
  #381
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Not sure if this is true, but I have been told that you can come by one of those pretty readily by getting one from a wrecking yard out of a V6 bird. They all used the same sensor.
Old Aug 14, 2024 | 10:40 AM
  #382
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Why does the 92 transmission have a mechanical cable speedo drive in it? All Camaros were electronic speedo in 1990+. (Firebirds changed in 1986).
You need to find an electronic speedo from a 90-92 T5 transmission. (86-89 is different signal). And the plastic gears inside the trans and the sensor need to match your rear end ratio.
I don't know about your odometer. That's driven by the speedometer itself.
Old Aug 14, 2024 | 11:28 AM
  #383
TorreZ28's Avatar
Maybe I was give the wrong info about the T5. If it is an older transmission from 86-89, what can I do to get the speedometer working?
Old Aug 15, 2024 | 02:38 PM
  #384
Kevin91Z's Avatar
See this reply.
And good luck, because they're discontinued and hard to find.
Old May 7, 2025 | 07:23 PM
  #385
kacyz28's Avatar
Is anyone still messing with these trans? I saw some thing that said the s197 V6 mustangs still used these and rated to 350 tq or 450 HP. Any swapping in newer parts?
85Irocbuild
Jun 4, 2025 10:26 AM
mooses8801
Jul 14, 2021 08:44 PM
midias
Dec 15, 2012 06:40 AM
Astro Perf.
Jan 29, 2007 08:24 PM
