What color speedo gears for 2.77??
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
As title states. I have an 88 IROC auto with a 2.77. Installing a reman trans and the one that was in it isn't original. I need to know what color driven and drive gears I need for correct speedo operation. Thanks. I did a long search and am way behind getting this car going. Any help greatly appreciated.
Car: 1980 Z-28 /1992 S-10
Engine: 496 /421 Stroker
Transmission: 700R4 / Tremec
Axle/Gears: 4.88 / 4.30
Re: What color speedo gears for 2.77??
This is the site I use , has all the calculators you need
I would start with a red drive gear , 17 teeth
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Here is the page with the part #'s for the driven and drive gears
http://www.tciauto.com/Products/comp...eter_gears.asp
Hope it helps
TOM
Hope it helps
TOM
Car: 1988 IROC
Thanks Nasty, that helps.
I have a yellow 19 tooth drive in it. This tells me to get a 41 tooth driven.
I will get one ordered, you are the man!
Car: 1988 IROC
Hey Tom, do you know what the difference between the two housing are?
the 34-39 and the 40-45? I have two 34-39, doh!
One sets the driven gear further out than the other , if you take notice the gear gets bigger with more teeth.
If you drop to a 17 tooth red drive gear , you could the use a 35 tooth orange colored driven gear which will re-use your housing .
That is providing you haven't already ordered them .
FWIW , I have a red drive and an Orange driven gear sitting right here if you need them . P/M me .
What is the tire height you are using for the formula ?
TOM
TOM
Car: 1988 IROC
Weeeeellllllll, too late, trans is in the car. I will get the bigger housing when I order the gear. Thanks for the offer though, it will be easier to swap the driven at this point. I was just hoping I could use the other housing. Thanks again for your help
, now if I could just fix the rich problem.............
ambainb
Apr 25, 2016 09:21 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
LT1Formula
Aug 20, 2015 09:36 PM
