what grade bolts to use to mount pressure plate to flywheel?
Old Jan 29, 2008 | 09:03 PM
tripingeorge3's Avatar
bought a t5 conversion kit, but the guy wouldn't give up the flywheel, or the bolts. i got the bolts to mount flywheel to motor , but not the clutch plate to the flywheel. i just bought some grade 8 bolts and lockwashers but they aren't black. does it matter ?
Old Jan 29, 2008 | 09:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what grade bolts to use to mount pressure plate to flywheel?
Just as long as they're grade 8. I'd also put some red locktite on the bolts and don't overtorque them. What size are the bolts?
Old Jan 29, 2008 | 09:29 PM
3/8 1 inch bolts with grade 8 lockwashers
Yes it matters.
DO NOT use regular hardware-store hardware for that!!!!! At least, not if you have decided that you like your feet, and would like for them to stay attached to your legs for as long as possible.
Both are "special" hardwares. Clutch bolts have a long shank that's larger, fits tightly in the clutch and about 3/8" into the flywheel, to make a sort of "dowel pin" effect; and flywheel bolts are unusual too. Readily available at almost any parts store, in the "performance" aisle, from Mr Gasket and others. Very very cheep - maybe $8-10 for a set of each.
Old Jan 29, 2008 | 09:46 PM
there were grade 8 performance bolts from murray's but they aren't black
Old Jan 29, 2008 | 09:54 PM
kcb37's Avatar
Get bolts from ARP. Their is a reason they are different from most bolts.
Old Jan 29, 2008 | 10:04 PM
they have a website
Old Jan 30, 2008 | 09:33 AM
they have a website
Summit does; Jeg's does; they're hanging on the wall at your local speed shop; maybe even at AutoZone, I think I've seen them there.
Old Jan 30, 2008 | 01:14 PM
Shagwell's Avatar
Car: projects.......
I would deffinitely buy the proper bolts for the flywheel and the pressure plate. As sofa said, the bolts have a shoulder where they contact the plate, thus there are no threads to chew up. - vatozone/discount, etc all have them in their craptastic performance isle.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Elliswon
Aug 10, 2015 12:33 PM
