TV Cable Install Help
Old Mar 13, 2008 | 05:43 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What is the easiest way to keep the hook that is in the tranny from sliding out of the hole that it goes into in the end of the TV cable? Everytime I hook it into the hole, it wont go in that far and as I lower it into the tranny it just pops out. Any ideas?
Old Mar 13, 2008 | 06:42 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TV Cable Install Help
have someone hold tension on the end by the throttle body. when this happens, it pulls the cable up into the housing preventing the wire link from coming loose.
Old Mar 13, 2008 | 08:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I had someone hold tension on it but after I have it in now, their is no tension when you pull on the tv cable from the top. How much tension should their be?
Old Mar 13, 2008 | 08:36 PM
87zjeff's Avatar
do you have it hooked up to the throttle body or is it still loose?
Old Mar 13, 2008 | 08:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
it is still loose. can that be why.
Old Mar 13, 2008 | 08:40 PM
87zjeff's Avatar
yeah, try connecting it to the throttle body. you should feel tension start to build as you connect it.
Old Mar 13, 2008 | 08:42 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
alright. ill give that a try
Old Mar 13, 2008 | 09:31 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
try disconnecting it from the throttle body. get the t.v. linkage connected to the cable then push the end of the linkage into the casing of the cable while still holding the the linkage. you may need to pull the linkage out of the trans a little. lower the casing to the trans while holding the cable connection up inside the casing.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
