TCC lockup kits?
Old Apr 6, 2008 | 05:55 PM
Spartan2832's Avatar
Car: 1986 Z28 Camaro
Axle/Gears: stock
TCC lockup kits?
I am wondering how these kits actually work? i think if your running without the computer this is neccesary to retain the lockup on your 700R4 but then does it run off of vaccuum on your carb? gonna be running one of these setups in my own import killer!!! lol but not sure what the complete theory behind it is and how its supposed to run with a "holley or edelbrock" carb? just confuzed on how the tv cable works as well as vacuum to control the shifting? anyone up to the task to explain this???
Old Apr 7, 2008 | 10:31 AM
Axle/Gears: stock
Re: TCC lockup kits?
anyone?
Old Apr 7, 2008 | 11:26 AM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
i wnet tpi to carb and lost my lock up. so what ever your converter is set at (2400 rpm stall) you will always be at or over that rpm while crusing. you will lose mpg and your trans will run slightly hotter, if you feel you need a lockup just install a lock up switch yourself. search the tec articles to find it. if your trans is too hot add a cooler
Old Apr 7, 2008 | 06:07 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
here is one link
https://www.thirdgen.org/torqueswitch
Old Apr 8, 2008 | 02:43 PM
Axle/Gears: stock
is that diagram of the plug that goes into the computer on the passenger side?
Old Apr 8, 2008 | 03:24 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
you need the lock up or you will burn up the converter down the road. Been there done that
Old Apr 8, 2008 | 04:28 PM
jstoltz's Avatar
no that is a diagram of the aldl connector under the steering wheel. there is another way to do it that works pretty good and makes it automatic. If you want to know how to do that lmk.
Old Apr 8, 2008 | 08:31 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
jstoltz, haha id like to know how to......
UltRoadWarrior9
Apr 28, 2020 10:39 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
customblackbird
Oct 1, 2015 04:30 PM
ramicio
Sep 28, 2015 01:18 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
