Tranny problem, I think?
Old Apr 26, 2008 | 04:20 AM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
Firstly. I'm new to this site, and am very impressed with it! I'm also a newish tbi owner. I dont know much about these cars, but I'm reading through the posts, and trying to learn! OK the problem i have, is the transmission (700r4 I guess), is slipping as i accelerate with a whining noise before changing up each gear. once rolling at highway speeds the noise seems to stop. I checked and replaced the fluid, although the old stuff diddnt look bad. I am hoping its not going to be too expensive, but i dont know if it is the transmission at fault, or maybe the torque converter, or something else? If i need to replace the tranny/converter, will any 700r4 work? or do i need a certain type? same for the converter? The car is a '92 firebird 5l (305) tbi by the way. Thanks in advance for any help you can give!
Old Apr 26, 2008 | 01:21 PM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
Re: Tranny problem, I think?
...still desperate for some help here... i need to fix this!
Old Apr 26, 2008 | 08:13 PM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
OK still no help! is it coz I'm English, or do i need a password? lol
Old Apr 26, 2008 | 10:01 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Someone who knows what to do will chime in soon for you.
I am new, too!
Old Apr 27, 2008 | 07:08 PM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
Re: some help.. please!
still need some advice.. please!
Old Apr 27, 2008 | 11:16 PM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
56 people have read this post, and the only person to reply is myself!! blimey i thought this was a really friendly site, with lots of help and advice. Did i title my post wrongly? Please, i really could do with some help from someone.
Old Apr 27, 2008 | 11:42 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
What kind of fluid did you use? it sounds like you put the wrong kind in.
Old Apr 28, 2008 | 12:23 AM
usrage0n's Avatar
Car: '92 firebird
Engine: 305 tbi
problem was there before the fluid change... but it was dexron 2 which was the recommended type. pretty sure its not a fluid problem, but thanks for the input!
Old Apr 28, 2008 | 12:29 AM
jeffcj's Avatar
Sounds like the torque converter may be on its way out.
Old Apr 28, 2008 | 07:04 AM
squeeezer's Avatar
Car: 5 cars
these trannies are cheap to replace
its hard to diagnose this problem accurately
i would suggest
1.transmission
2.performance converter
3. with a trans go kit
4. upgrade the input drum if you can
5.make sure the t.v. shortcommings are taken care of for a healthy 3rd and 4th gear
sorry i couldnt help more but im not there with your car either
if you hear a whine first thing after low fluid i would think of is a bad pump
Old Apr 28, 2008 | 07:13 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Is it more of a lag between shifts and kind drops and jerks into gear? Test the TCC solenoid. Do a search. Theres a few different tests you can do. If you cant find anything let me know.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
