engine removal help
Car: 87 Silver Formula
engine removal help
we have everything removed that could be holding the 305/700r4 in the car.we start to lif the engine out and the drivers front tire is being lifted.we cant seem to see what it sticking.
anyone have some advice
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: engine removal help
something has to be holding it somewhere. It could be in the motor mount. It could be exhaust. If you cant see anything even after looking very very thourghly, then take a long pry bar and see what you can do to nudge it loose.
its pretty simple, something is still connected or its hitting something. Find it and solve it.
Car: 1986 Z28
Engine: 355
Axle/Gears: open 2.73's
Try checking the bolts from the flywheel to the torque converter. We removed them when took out my 305 to replace it with the 350. This may not be the problem but worth a shot. Good Luck
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
3rd Gen said it perfect. Every Chevy I have pulled has involved a crowbar. It's just that they have been in there so long stuff gets sticky. Another trick that i used is make sure you take the radiator out and put something in front of the block. Then back up the cherry picker about 6-8 inches so its pulling at an angle when the car starts to lift shat the &^$^% left and right and it should give way. Let me know how it goes.
Trey
Trey
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Six (6) transmission to engine bolts
Three (3) converter to flywheel bolts
Two (2) motor mount bolts
Four (4) exhaust flange to manifold bolts
2-3 ground to head/intake wires depending on year/type
Oh and make sure you remove the little clip that holds the tranny cooler lines to the pan or else they'll be sproinged up into the air when you're done.
Looks like you're pulling eng/tranny together? If you've dropped the rear of the tranny it's easy for the motor to get jammed up on the motor mounts. Try to lift it up with the rear of the tranny up some.
Engine: 350 Crate
ooo I forgot about that I hated that. Engine #26. LMAO
she was lifting pretty good.
and yes,i am lifting both the engine and tranny at one time.
you can see in the second pic how far it has went but not enough to clear the mounts.
exhaust manifolds need to come off now or will it come out like it is?
as you can see,i have plenty of room to work.car was wrecked in the front and we cut it all away.
we have the tranny jacked and are working it with the engine as we lift.
Car: 88 IROC
I still say pry bar.
drop the k member?
something is in a bind, its that simple. Its not black magic.
try moving the tailshaft around. where does the movement center around? Try the same for the front.
and when all else fails, stick a long pipe against the manifold and the frame rails or inbetween the motor mounts and pry it loose.
drop the k member?
Ain't got it out yet? That thing's wide open. Second above, pry bar at the mounts. Anything else holding it would be obvious.
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
lol i had a hell of time getting mine out but what i did was stood on top of the egine and just started rocking it the engine and tranny like to come as one.
Engine: 350 Crate
Crowbar!!!! And like 91327 said stand on that bia bia and rock. Maybe when it got wrecked it bent something back that is holding it in.
Car: 84 z28
Engine: 383 stroker
Transmission: th-350
Axle/Gears: 3:42
2 things i can think of.
1. I can't see what's going on in that second pic either, you may have the exhaust pipe dropped and we are looking at the flapper valve for the A.I.R .
2. Let the tranny down, remove the tranny crossmember. If you have that tail end jacked up and them are jacking up om the picker then the tranny will hit the tunnel and won't go anywhere.
If you let the tranny down the motor moves up and it will come out at a angle.
