9 bolt??????
Old Jun 12, 2008 | 01:36 PM
19formula30589's Avatar
Car: 89 Formula
9 bolt??????
i have a 89 formula w/ a 9 bolt how much power can they hold not launching it or beating on it i also dont know the ratio but its got a t-5 and it tops out at 140 so im sure someone will know the ratio hahaha thanks in advance
Old Jun 13, 2008 | 01:17 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 9 bolt??????
You probably have a 3.45 ratio rear end and it can hold up to at least 400 HP.
Old Jun 13, 2008 | 10:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 9 bolt??????
An '89 TPI with a 9-bolt, so I'm guessing you have a dual-cat exhaust too? That would make the rear end ratio 3.45, as bjankuski said.
Old Jun 14, 2008 | 12:11 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: 9 bolt??????
Some can't even hold up to stock HP.
Old Jun 14, 2008 | 12:28 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt??????
How do you come to that conclusion? That are way stronger than 10-bolts.
As for 3.45 ratio....I pulled a 3.27 out of a 89 350/Auto GTA.
Old Jun 14, 2008 | 08:40 PM
Kevin91Z's Avatar
Re: 9 bolt??????
2.77 or 3.27 came with 350/automatics, while 3.45's came in 305/5-speeds.
Old Jun 14, 2008 | 11:01 PM
grizzlyta44's Avatar
Car: 1986 Trans AM
Engine: 305ci tpi
Axle/Gears: 2.77 Borg Warner
Re: 9 bolt??????
Does anyone know where to get the Axle bearing retainers for the 9 bolts? I am having a bitch of a time getting them. From what I understand is that when they are installed they stretch to ensure a tight fit therefore not to be re-installed as they are already worn. Is there a rebuild kit that contains them? I am certain that someone has to have these stupid things as you need to remove them to change your axle bearings.
Old Jun 18, 2008 | 11:24 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: 9 bolt??????
Just reuse the originals..I have a few times and the seals don't leak.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
