700r4 tranny and a 10 bolt....both upgraded and rebuilt, but it won't last right?
Old Sep 13, 2000 | 12:57 PM
crazeinc's Avatar
I want to put in a 406 this winter and I have a 10k mile 700r4 with shift kit and a 100 mile 10 bolt with richmond 4.10's and an auburn posi unit and I'm a little distressed all this work will be for nothing if the engine tears them apart....
At what TQ, will I need to start worrying about this stuff?
Thanks.
-'82 Z28 (350, carb'd, 4.10's, Super Comps, plenty of goodies)
-'91 S10 (nice daily driver)
AIM me at: Unitedhope
ICQ me at: 77979548
Old Sep 13, 2000 | 01:37 PM
89ProchargedROC's Avatar
10 bolts die all the time, sometimes from just normal abuse and driving. I have a friend who used his 700 into the low 11's before he kept braking it. Remember though this was an expensive and very strong built trans.
Old Sep 15, 2000 | 09:33 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
This website has some info on the strength of the 10 bolt: http://www.isthq.com/~dan/10bolt.html
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
Old Sep 18, 2000 | 09:53 PM
crazeinc's Avatar
Anybody wanna buy a 10k mile 700r4 with shift kit and a 100 mile 10 bolt with richmond 4.10's? what a joke...looks like I'm upgrading to a ford 9" and a TH400 or T56 this winter along with my 406
ICQ me at: 77979548
Old Sep 18, 2000 | 11:18 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Ihave seen 700R4's take all kinds of crap, so my suggestion is to keep the tranny and get either a ford 9" or a strange 12 bolt. Right now I am running a 700 R4 with about 500H.P. and 480 ft/lbs of torque in front of it and its working fine. The 10 bolt rear is a whole different story, I went through 3 auburn carriers and the straw that broke the camels back for me was a broken axle. So, I junked my 10 bolt and put in the Strange 12 bolt. Anyway, back to the tranny, if you want a TH400 go for it but I would think again about the T56 because I have a few friends who spent several weekends changing clutches, and after a while they got sick of it a they both switched to TH400's.
Neil 383 IROC-Z: TFS heads/JE pistons 10.8:1/ 24lb/hr SVO inj./ Edelbrock Runners&Base/ Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter & much more.........
Old Sep 19, 2000 | 12:38 PM
CamaroMike's Avatar
Neil tell me about your 12 bolt. How hard was the install, what brakes are you running, how much did it cost you, will the wheel studs clear my centerline wheels? Thanks in advance.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Sep 19, 2000 | 01:51 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Mike,
The install was relatively easy, however, I did have to upgrade my rear brakes to the 4th gen calipers. The cost including calipers, power slot rotors, russel brake lines and the rear end itself was around $3500.00. Concerning the studs and your centerline wheels, I would call Strange Engineering and ask them.
Oh, the reason I had to upgrade to 4th gen brakes was b/c they only sell the rear end units with 4th gen caliper mounts. The only difference between the 4th and 3rd gens, is that the 3rd gen rear-end is approximately 3-4" shorter.
Old Sep 19, 2000 | 09:56 PM
CamaroMike's Avatar
Thanks Neil! Damn that rear assembly was expensive!!! My 7.5 has 3.73 Richmond gears, a cone posi out of an early 80's Monte, 26 spline axles, axle tubes welded around their circumference at the carrier, aluminum support cover and a zytanium cross pin. Before the cross pin and support cover I was running slicks to 1.88 60 foot times. I wish I had 28 spline axles and the Torsen SLP carrier but oh well. When my rear blows I plan to get a third gen rear with disc brakes and build it to the max with aftermarket axles and all but I am worried about future mods and horsepower destroying that ten bolt. There really is not cost effective rear for our cars. I did find that SLP had a Dana 44 left for our cars but it's 1700 bucks and the twelve bolt is only 300 bucks more. Any input or thoughts would be appreciated.
camaro11j
Sep 19, 2018 08:49 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
