Clutch problem
Old Aug 11, 2008 | 04:58 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
Clutch problem
My clutch has been slipping for a couple of weeks now. I have been looking into replacing the clutch in the near future, but a new problem came up. When I was going home from work, I started my car. When I started to go, I immediatly noticed something wasn't right. It took almost no pressure to disengage the clutch. About the last 75% of the clutch pedal throw was very loose (almost floppy). I was able to get home, and park my car. I tried starting up again once I was home, but now the clutch won't disengage enough to get it to shift into gear. Can someone give me a suggestion on what to do, or what the poblem could be? Also, what would the price be for a shop to do the work (I don't have the tools or experience to pull the transmission)?
Old Aug 11, 2008 | 05:33 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Clutch problem
that happened tro my friends 95 cobra, it was the clutch going out, cost him 8 or 900 parts and labor at a good, reasonable local place
Old Aug 11, 2008 | 06:17 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Clutch problem
Your clutch problem just went into complete failure mode. Where you hoping it would repair itself??? Start checking the yellow pages and start getting quotes including towing. Not going to be cheap.
Old Aug 18, 2008 | 11:16 AM
miner's Avatar
Car: 88 Iroc-Z
Re: Clutch problem
The slave cylinder was leaking. I replaced it and my car is driveable for now. I have a 1988 IROC-Z with a 305tpi and t-5 manual. Is there an easy way to know if I need a 10 spline or 26 spline clutch?
Old Aug 18, 2008 | 01:57 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: Clutch problem
If its stock, it should be 26..... 10 was only in the V6's...
Old Aug 18, 2008 | 02:39 PM
BladeX10's Avatar
Car: 1991 RS v8
Re: Clutch problem
I know my car has a real hard time shifting into 1st and reverse.. I went through my paper work and found a receipt of a clutch job 2 years ago.. The clutch only has 6k miles on it.. So i knew it couldn't be going out already.. Then i read on and it said my clutch release rod needs to be extended because they used all of the adjustment. So i'm about 90% thats the problem with mine..
Dont know how old your clutch or all of the problems but it could be possible. :P
Old Aug 18, 2008 | 04:51 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: Clutch problem
He has a hydraulic setup for his clutch release, I think yours (if it is indeed an 83) actually has a manual linkage. There is no way to adjust a hydraulic setup.
Old Aug 18, 2008 | 04:55 PM
miner's Avatar
Car: 88 Iroc-Z
Re: Clutch problem
Ok, thank you.
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
