T5 swap, going crazy!!!!
Old Aug 18, 2008 | 02:13 PM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
Transmission: T5, b&m short throw shifter
Axle/Gears: 3.27 borg warner
ok im at my wits end here, first of ive read all the sticky's and iv'e done searches but its all just to confusing so im hoping someone out there can put it all in prospective for me, ok let me tell you what all iv'e got going on, ok first thing i have a 89 350 tpi trans am gta with a 700r4 and 3.27 gears, ok i swapped out the tranny to a T5 that came out of a 91 firebird 305 tpi, alright so im done with all the other stuff except the wiring and the drive gears and driven gear and vss and reverse lights, ok now i did take the vss off the T5 and look down in there with a flash light and it has a blue gear, and the other gear is white, ok so what im asking is can someone tell me what parts im going to need to wire up the reverse lights and what gears im gonna need and what vss im gonna need and all that good stuff, plus part numbers would be GREAT or were to get these parts, also one more thing what do i do about the computer or prom/memcal ????? PLEASE I JUST WANT TO GET MY CAR DONE!
Old Aug 18, 2008 | 06:38 PM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
Re: T5 swap, going crazy!!!!
any help?
Old Aug 18, 2008 | 10:29 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
far as the gear go i can't remember what I used on mine, but to do the wirring for the reverse lights just use the plug and lead you should have removed from the donor car. It's the one mid way up the case on the driver side I want to say. There should be a blue and green wire that used to run to the automatic shifter. Cut those and splice them to the wires on the plug that goes to the reverse sensor on the tranny. It doesn't matter which goes to which because all they do is complete the circuit to turn the lights on. If the wires are a different color just strip the 4 lighter gauge ones and put the together until you get the reverse lights to come on.
Old Aug 19, 2008 | 10:23 AM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
i bought the set up over the internet and the did not send the plug.
Old Aug 19, 2008 | 11:55 AM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
ok so i think i was just really tired last night but i got everything figured out now except i cant find a vss for the trans, it has the 4000 pulse 91 vss in it and i need the 2000 pulse for a 89???
Old Sep 21, 2008 | 04:15 PM
lilli's Avatar
Car: 1992 firebird
Engine: 3.1 V6
Transmission: borg-warner T-5
Axle/Gears: 3.42 posi
I don't know, but I think that 350 is going to have too much torque for the t5. it probably wont last long in there. I'd be careful with it.
Old Sep 21, 2008 | 11:32 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
I made the swap in early March. I haven't dropped the clutch on it, but I have spun the tires on mine without a problem. My problem is that I need to go from a vss to a conventional cable speedo. Right now I'm using gps for speed.
Old Sep 22, 2008 | 09:45 AM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
since this post ive got everything figured out and done! I found the correct vss from someone one this site, ive got the reverse lights hooked up right and everything looks so good and works great! def. the best decision ive ever made!
Old Oct 1, 2008 | 10:30 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
where do the wires for the reverse lights come from? My car was an original 5 speed car, but now I run a glide and needing to find the wires for the reverse lights. I don't remember cutting the wires that went to the T-5 but dont see anything under the car except for the speedo cable. If I knew what color the wires were or where they ran to I can make it work.
Old Oct 2, 2008 | 11:32 AM
MY_GTA's Avatar
Car: 1989 GTA
Engine: 5.7 l98
you know im not sure where your reverse light wires are cause my car was originaly an automatic, but on mine the reverse light wires were attached to the gear shifter, anyway the wires are green and blue on auto's and manual's.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Papaginos
Sep 27, 2015 03:29 PM
hectre13
Sep 8, 2015 03:38 PM
aaron7
Aug 26, 2015 09:45 AM
Fronzizzle
Aug 19, 2015 01:36 PM
