what kind of gears and differentials do you guys roccomend?
Old Dec 24, 2000 | 06:06 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
in teh spring i gotta get my rear end doe, but i was wondering which gears and diff. i shoudl go with.
SLP has their kit that has a Torsen carrier and OEM gears(3.73s), but i dont knwo if its what i want.
what do you guys use? auburn? gm motive? any suggstions??
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 24, 2000 | 11:32 PM
ede's Avatar
ede
i like richmond gears. lot of people say they make more noise than other gear sets, but that's what i like. slp had and maybe still does good prices on posi carriers. if it were me i'd most likely buy the cheapest carrier, since i'm figuering none of them are junk pieces.
ICON Motorsports
1st & 3rd
Old Dec 27, 2000 | 11:34 AM
nickd's Avatar
I had a Richmond 3.42 gear in my 92 and had no problems, it was not any noiser than the stock gear either. It's all in the set-up.
As long as your set-up guy is good and very experienced you shouldn't have any problems.
Otherwise I would stick with GM gears.
1994 LT1 Corvette Convertible
Old Dec 27, 2000 | 12:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
One of the easiest and cheapest swaps is to get the SLP take-off torsen posi (you can use it because 1991 cars have 28 spline axles) for $100. Then head over to the www.camaroz28.com or www.ls1.com classified boards and look for someone selling their OEM 3.23 or 3.42 gears. They'll fit just fine, and wont cost a whole lot. Then find yourself a shop to install it for you (unless you have your own pinion setting kit). Lastly, you'll need to change the speedo gears in your trans to match your new rear end gears. I think that info is in the FAQ on this site. The shop who does the rear end install should be able to swap the speedo gears as well.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 29, 2000 | 10:18 AM
82camaro's Avatar
Car: 82 camaro SC
I've used most all the differentials available. My favorite by far is the powertrax. My reasoning is that it's the easiest to install and provides the best traction as well as being strong.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 3, 2001 | 11:49 AM
91' Camaro Man's Avatar
With that powertrax diff. was it worth the more expencive price that i comes with? And what kinda torque and power are you running on that 7.5 gear?
Love you Camaro, love your wife/girlfriend, BUT ALWAYS PUT GOD FIRST!!!
1991 LO3 305 RS Camaro w/Headman headers and custom dual exaust.
Old Jan 3, 2001 | 06:37 PM
ede's Avatar
ede
hey kevin i have gm 3:42 gears i'd sell
ICON Motorsports
1st & 3rd
Old Jan 4, 2001 | 12:04 AM
pimpintheRS's Avatar
ede how much for the 3.42's?e-mail me if he dont want em
Old Jan 4, 2001 | 12:59 AM
Kevin91Z's Avatar
Are you talking to me? I have a 9-bolt, and I'm putting 3.70's in it. I dont need 3.42's.
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
86IROC112
Aug 17, 2015 07:57 PM
Street Lethal
Aug 14, 2015 08:25 PM
novaderrik
Aug 10, 2015 12:44 PM
