Roller pilot bearing problem
Old Jan 4, 2001 | 07:49 PM
Tom Keliher's Avatar
I bought a Moroso roller pilot bearing and today I tried to install it into the crank. First, the directions said it had to be pressed in using an arbor press. yeah, that's great if you have the crankshaft on a bench.
Well, it would not fit. It is designed as a very tight tolerance fit and I tried tapping it in with a brass drift like a wheel bearing but it messed it up so I had to use my die grinder and cut it out.
Has anyone converted from auto to manual and used a roller bearing? Which manufacturer fits? Or am I going to have to use the bronze bushing instead?
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Jan 4, 2001 | 09:41 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I think you can just get a T56 pilot bearing it fit in mine
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jan 5, 2001 | 06:38 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
When I went from auto to stick the normal dorman pilot bushing got chewed up so I put in a roller bearing that I got from gm, when I swapped motors I got a new roller bearing from carquest. I just asked for one So I don't know what kind of car it was for, I seem to think it came from a heavy duty truck.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jan 5, 2001 | 07:13 AM
Cowboy's Avatar
I got mine from GM made for a T-56. I haven't fit it in yet cause its been to cold around here lately to get any work done.
Old Jan 5, 2001 | 10:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have used many of both the GM and the Moroso bearings, as far as I can tell they both came from Acme Pilot Bearing Co. or one of their affiliates. They appeared identical in every respect. Both of them are indeed a tight fit. However, I have never had access to an arbor press, I just use a brass drift and lots of patience. They are definitely tougher to put in than a bushing but by no means impossible.
Get another one and try not to get in too much of a hurry, it will go in OK. Cranks are all also the same whether they came in an auto car or a stick car so changing over is not an issue.
Old Jan 5, 2001 | 02:52 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I too did the same thing but I got it about 3/4 of the way in and it got screwed. I had to chisel it out. That totally sucked. To put the new one in I used a dremel sanding drum and took a little material out to get the new on in.
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Jan 5, 2001 | 03:35 PM
Christobal's Avatar
Tom
I used the Moroso unit, which should be the same one you used, as I think there is only one version for both small and big block Chevys. It was 'tapped' in with a socket and rubber hammer while still in the engine and the car. It was quite a while ago, but i don't remember having much difficulty. I haven't had any problems with it that I am aware of.
Old Jan 5, 2001 | 06:16 PM
Thanks everyone for replying.
After talking it over with a buddy at work, I decided to go with the bronze bushing.
I could put a roller bearing in and like you said, take my time and not be in a hurry and I also could freeze it and I know I could get it in OK the 2nd time around.
However, after discussing it with my co-worker I decided on the bronze bushing.
Reason being is that he said high winding engines, for long periods, are better off with a bushing. Drag racing engines, which get torn down after every few runs are good to go with the roller bearing. His theory, based on his experience as a crew chief on circle track cars is that a bushing can only "wear". But a roller bearing, can "come apart" and if that happens, the loose free play can cause serious damage. But with a bushing, the worse that will happen is some excess wear. I thought about that, and it convinced me to go with the bushing instead of the roller bearing.
dyeager535
Aug 28, 2015 08:10 AM
19irocz85
Aug 26, 2015 07:54 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
