driveshaft lenght help 700r4 to th350 swap
Old Jan 17, 2001 | 04:47 PM
Whirlyduck's Avatar
i have an 88 iroc z with the stock 700r4. in the spring i want to put a th350 in it. first of all, what is the stock lenght driveshaft and second what lenght shaft do i need to get to do the swap. i am considering an aluminium one. where sould i go to get one. anything will help, thanks
Old Jan 17, 2001 | 04:49 PM
ede's Avatar
ede
3rd gen drive shaft will work, you'll neeed to buy b&m pn 30299 to make it all work.
ICON Motorsports
1st & 3rd
Old Jan 17, 2001 | 05:07 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
there are two different driveshaft lenths for the Thirdgens. one was for the TH200C. and the other is for the 700R4. to put a TH350 in your car you will need the TH200C driveshaft(you can get one out of an 82 T/A or 82 camaro). the 700R4 driveshaft is too short because the 700R4 tranny is longer because it has 4 gears instead of 3.
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, Eldebrock Headers, 3" Hooker Cat-Back, duel outlet with quad tips.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns.
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
Old Jan 19, 2001 | 08:57 AM
82camaro's Avatar
Car: 82 camaro SC
Th350 length
6" tailshaft
27 11/16
9" tailshaft
30 11/16
12" tailshaft
33 27/32
700r4
All except Corvette
30 3/4
Corvette (1984-1996)
29 7/8
The th200c shaft is about the same length as the th350 6 inch tail shaft, so that drive shaft will work.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 20, 2001 | 08:38 AM
ede's Avatar
ede
i've put 9" th350s in a 88 that was a 5 speed and in a 85 that was a 700r4 with out changing drive shafts.
ICON Motorsports
1st & 3rd
Old Jul 13, 2010 | 02:58 AM
CamaroIROC88350's Avatar
Re: driveshaft lenght help 700r4 to th350 swap
[quote=ede;300355]i've put 9" th350s in a 88 that was a 5 speed and in a 85 that was a 700r4 with out changing drive shafts.
ICON Motorsports
How did you do that without changing it?
Old Jul 13, 2010 | 03:44 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
01-20-2001, 01:38 PM
ede
Old Jul 13, 2010 | 05:10 AM
ede
I was looking for info on putting the 350 turbo into my car and this thread popped up on Google. I don't normally look at the dates on these threads.
Old Jul 13, 2010 | 10:31 AM
86 LT1's Avatar
if you dont already have a good th350, check out trans specialties they have been in business for over 30 years and build some tuff stuff,i think my competition th350 was 846.00 with the 9" tailshaft bolted right in
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
