need help with 700R4 trans
Old Oct 26, 2008 | 01:01 AM
mike91camaro's Avatar
Car: 91 camaro rs t-tops
Engine: 305ci tbi
i have a 700R4 trans in my 91 camaro rs i will shift into over drive when i let off the gas on the high way and when back into the gas it jumps back to 3rd but i adjusted the kick down cable on the tbi and shifted better but not into over drive but i have a 89 1/2 ton truck with a 350 create with less then 4,000 and new 700R4 trans im taking out off it but can i put the trans in my camaro rs i heard if i change the tail shaft it would work just fine has any one done this before please help
thanks
Old Oct 26, 2008 | 01:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help with 700R4 trans
That's normal. Overdrive is for cruising, not accelerating.
Old Oct 26, 2008 | 07:02 PM
Engine: 305ci tbi
its not that its when you let all the way off the gas not even touching it it will shift in to o/d and as soon as you touch it any gas it will shift back to 3rd thats at any speed on the high way but plan on taking it out and putting my other one in its out of my truck i heard i just have to change the tail shaft and it would be good to go do you know if it would work and any good shift kits to put in
Old Oct 26, 2008 | 10:40 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
How did you adjust the tv cable. Did you use a gauge or just setting it as all the way open at wot. Is it a stock throttle body your using. as far as a good shift kit get one from pro-built.
Old Oct 27, 2008 | 11:09 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
What about those kits that make it do like vettes, and change the kickdown from 50% throttle to 85% throttle? Maybe our member from pro built automatics should know. I've never wanted to try these kits myself.
Old Oct 28, 2008 | 12:55 AM
Engine: 305ci tbi
i adjusted it wot i pulled it out and the push the gas down and then i tryed it by turning it by hand and still not working
Old Oct 28, 2008 | 01:32 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
i know mine does the same way and i believe its pretty much the same car as yours but my gas pedal is EXTREMELY sensitve and if i hit a bump in the road it will drop o/d. so i try and be very gentle on the gas.
Old Oct 28, 2008 | 11:15 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
you have to change the output shaft also not just the tail housing
Old Oct 29, 2008 | 09:09 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That depends. Changing the output shaft is only necessary if the truck was 4 wheel drive.
Old Oct 29, 2008 | 11:51 PM
Engine: 305ci tbi
yes the truck was 4 wheel drive
Old Oct 30, 2008 | 04:32 AM
90_WS6_Formula's Avatar
Car: 91 Z28
you push it in and when you step on the gas peddle or open the throttle by hand it will ratchet out and you should hear a series of clicks
BlueIroc-Z
Jun 9, 2019 03:22 AM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Aug 6, 2015 04:15 AM
