how to tell if you got a 7.5 or 7.65 10-bolt
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
I have a 88firebird formula ws6 with a 305tbi/700R4/ and i know its a 10-bolt open diff. I want to beef it up but I need to know if its a 7.5in or 7.65in
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how to tell if you got a 7.5 or 7.65 10-bolt
if its the original rear its probably a 7.625, but that number means nothing for most upgrades.
it only matters if you are swapping the innards of the carrier, because the spacing inside, where the spiders gears/posi unit go, it different by about a quarter inch.
But nobody does that, they just swap out the entire carrier. Unless you are buying a powertrax locker.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Around 1986, GM upgraded to 7-5/8". Nothing else is different, just the size of the ring gear was increased. 7-1/2 and 7-5/8 components are the same.
Even though the ring gear is 7-5/8, the diff is still called a 7-1/2".
Yours will have 26 spline axles unless a previous owner upgraded to 28 spline.
Engine: LO3 305 tbi
Last edited by FireTurdWS626; Nov 30, 2008 at 01:44 PM. Reason: Automerged Doublepost
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yes either carrier size will work, but you will need a 26 Spline as a must.
Engine: LO3 305 tbi
Car: 87 IROC L98
You'll need 28 spline axles specific to a third gen. 90-92 third gens got 28 spline axles but any aftermarket ones for 82-92 will work. There are no other factory 28 spline axles which will be the proper length.
Engine: LO3 305 tbi
alright guys i think i soaked it all in thanx for all the help
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
So, if you have a 7.5 rear you can go ahead and purchase a carrier meant for the 7.625 and use said 28 spline axles? Seeing that summit doesn't offer a 28 spline carrier for the 7.5... Sorry for my noobness, but just started looking into this.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The carriers, and absolutely everything else except the gears themselves are exactly the same. For all intents and purposes, the 7.5 and 7.625 are one and the same.
Engine: LO3 305 tbi
Just a heads up for my rearend build i ended up using axles from Yukon, a eaton posi unit, and richmond gear set (3:27) and finished it off with a TA performance cover w girdle. while i had the axels out i upgraded the rear brakes with a package from hawksthirdgenparts.com
Actually, if you want to get technical about it, you upgraded to 3.23 ratio. The 3.27 ratio is only in the Borg-Warner 9 bolt rears. 3.23 is the 10 bolt ratio.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
