700r4 pics
Old Apr 2, 2001 | 08:36 PM
v6-3.1's Avatar
700r4 pics
can anyone please post pics of the tranny, such as the internal components,
Old Apr 3, 2001 | 09:35 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Heres a SMALL sample of some of the pics for my tech article i'm putting together. A step-by-step for the beginner. Hell it's only the 3rd trans I ever did (1st powerglide, 2nd was a friction replace on a 700r4 and this one is complete down to every piece) The only part I got in the case is the 2 checkball capsules (Thanks for info Pro-Built!)
It's 16 pics and not all of them. I want to photo EVERY step. Sorry I can't give descriptions as the pics are different #'s now and don't match the photopoint #'s. I didn't even get the bushings in the case yet so it really is a work in progress. Is there a certain part you need a pic of? (Now is a great time!!!)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
JoelOl75's Avatar
Old Apr 3, 2001 | 09:42 AM
JoelOl75's Avatar
The one photo of the frictions (well they look like steels now) are from the 3-4 clutch pack. And think. these shifts are not the ones i was complaining about! (You should see the band!)
Old Apr 3, 2001 | 11:05 AM
v6-3.1's Avatar
is there anyone out there with pics from a text book, they seem to be more detailed.
thanks for the pics
Old Apr 3, 2001 | 04:41 PM
JoelOl75's Avatar
What part of the transmission do you need a pic of? (from a book). I can't scan the whole rebuild book. I'd suggest buying a book, or if it's a certain area you are working on (like installing a servo, or a shift kit,ect.) i can help.
Old Apr 3, 2001 | 05:05 PM
v6-3.1's Avatar
I wanna do a rebuild.I wanna replace the bands
Old Apr 4, 2001 | 06:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Bwwwaaaaahaaaaahaaaa! You win the "most creative" award, Joel. I have never EVER seen anybody tear down an input housing like you! Not trying to flame you, but using two C-clamps and a 2nd Piston housing between your legs is PURE creativity. Haaahaaahahahaha. In the meantime, I will live my boring life using Kent-Moore tools. I remember the days when I used to do TH350s by sticking the tailhousing down inside a cinderblock!
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 5, 2001 | 07:15 AM
JoelOl75's Avatar
If I had to re-do alot of them. I would get the tools too. But for once-in-a-while stuff...
Where there's a will theres a way. (You should see how I get the reverse-low spring retainer out. With a pitman arm puller, 1/2" threaded rod and 2 large washers.) Hey it works. And I don't see spending over $60 for the kent-moore tool to use a couple times and take up space in my toolbox. That spring retainer and the one in the pic you mentioned were the two most diff areas I had. The rest isn't too bad.
It's better than building plastic models and at least you get to sit down most the time.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Vojtush31
Oct 11, 2015 01:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
