rear axle rebuilding tips
Old Jan 6, 2009 | 05:51 PM
D&S 85 IROC's Avatar
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
Can anyone give me some pointer and direction on rebuilding the posi unit in my 85 IROC? It has the 3:42 gear ratio and is a posi. Any help would be greatly appreached. Thanks
Old Jan 6, 2009 | 05:59 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rear axle rebuilding tips
Limited Slips (posi) in 10-bolts cannot be rebuilt.
Old Jan 7, 2009 | 08:23 PM
Car: 85 IROCZ
Axle/Gears: 3;42
So I should look to replacing the carrier
Old Jan 7, 2009 | 09:36 PM
big gear head's Avatar
Depends on which one you have. It could be the Governor Lock or Auburn. If it is an Auburn then take it out and toss it in the scrap metal pile. Be ready to clean the housing and axle tubes out well because the Auburn fills the rear end with powdered metal. The Governor Lock can be rebuilt, but not without special tools.
The best thing to do is replace it with a new Eaton posi or Truetrac. The one you choose depends on what you want to do with the car.
Governor Lock
Auburn
Old Jan 7, 2009 | 11:14 PM
Car: 85 IROCZ
Axle/Gears: 3;42
Well I have the Gov lock. Was looking at the true trac today in the new summit book. Tough desision................... NOT!
Just for S@#% and giggles how hard would be to rebuild the gov lock? Where can I get the parts from?
Old Jan 8, 2009 | 05:08 AM
DJP87Z28's Avatar
Not worth the time and effort.
Old Jan 8, 2009 | 07:09 AM
The tool to disassemble the Gov Lock is over $130. What parts are broke in it? The parts come from GM.
I have the tool and can rebuild it for you if you want. I have rebuilt many of these.
Old Jan 8, 2009 | 05:57 PM
jackaa2009a's Avatar
On Probation
wholesale2
wholesale wedding dresses, wholesale wedding dress,wholesale wedding gowns,wholesale wedding dresses, wholesale wedding dress如果此信息影响了论坛,请及时删除
Old Jan 8, 2009 | 07:32 PM
Car: 85 IROCZ
Axle/Gears: 3;42
It's just plain wore out. There is about a half of a turn in the driveshaft before the tire even start to rotate.
Old Jan 8, 2009 | 07:40 PM
What are you going to do with it? I might be able to use parts out of it.
Old Jan 8, 2009 | 07:44 PM
Car: 85 IROCZ
Axle/Gears: 3;42
Oh don't know yet. The car is all orginal numbers matching, I guess I was just going to keep it for now and if I sell the car it could go with it.
What's the difference between a truetrac and a eaton carrier
Old Jan 8, 2009 | 07:52 PM
The Eaton uses clutches to lock both sides together. It can be adjusted for more or less slipage in the clutches, depending on how you want it to act. It is also completely rebuildable.
The Truetrac uses resistance in worm gears to distribute power to both sides. They are smoother in curves, but can sometimes slip when doing burnouts.
I prefer the Eaton for street/strip cars and the Truetrac for road racing and autocross.
I have a Governor Lock that is rebuilt. I don't remember if it's 26 or 28 spline. I can check it if you are interested. I sell them for $250.
Old Jan 8, 2009 | 08:07 PM
Car: 85 IROCZ
Axle/Gears: 3;42
Thanks for the offer I'll let you know what direction I going to go. if I decide to buy your gov lock would you want the old core? Without counting the splines I couldn't tell you if It's 26 or 28. My guess is 26 cause it's all stock and the orginal rear.
Old Jan 8, 2009 | 08:15 PM
The '85 will be 26 spline. I might be interested in the core if I have parts to go in it.
Old Jan 8, 2009 | 08:41 PM
Car: 85 IROCZ
Axle/Gears: 3;42
Ok. Thanks for all you help and insight.
Old Jan 9, 2009 | 07:33 PM
Pat Hall's Avatar
I wouldn't spend $25 on a Gov-Lock, let alone $250. They're weak and prone to failure, that's why they're commonly nicknamed "grenade-lock". They work okay in 4WD trucks since dirt allows some slippage when they lock up. When they lock up quickly on dry pavement, they like to explode into shrapnel. If you plan on keeping and driving the car for a long time, I'd suggest sealing up the original Gov-Lock in a plastic bag, sticking it on a shelf in the garage, and then install an Eaton clutch type unit. The Eatons are tough as nails, and fully rebuildable, unlike an Auburn. If you're on a budget, the Truetrac isn't a bad choice either, and can be bought for cheaper than an Eaton. Whatever you do, don't even think about one of those no-slip locker units from Powertrax or Richmond. They jerk and bang so badly in a street-driven car, it'll drive you nuts! Had one of those in my 69 12 bolt rear for a while. Never again.
Old Jan 11, 2009 | 06:03 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Gospel my friend , as true as gospel.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Warlocksirix
Sep 3, 2015 12:26 PM
E Rod
Aug 28, 2015 05:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
