CONFUSED
Old Jan 24, 2009 | 11:00 PM
supreme4life's Avatar
CONFUSED
does anyone know the spline for the differentials for an 88 tbi camaro ? at lest thats what it started life as. is it 26 or 28? i read 88-up is 28 and seen 76-88 is 26.
Old Jan 25, 2009 | 12:31 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: CONFUSED
IIRC, camaros didnt get 28 spline axles till 90, also IIRC, the 89 RS i parted had 26.
Old Jan 25, 2009 | 09:09 AM
big gear head's Avatar
Re: CONFUSED
That's right, it will be 26.
Old Jan 25, 2009 | 02:15 PM
Re: CONFUSED
Old Jan 26, 2009 | 12:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: CONFUSED
Where did you read that 88 and up is 28 spline? Its 90 and up for f-body 10-bolts. I'd like to find that link and fix it.
Old Jan 26, 2009 | 02:18 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: CONFUSED
he may have read it off-site, in 88 s10's started getting the 28 spline stuff
Old Jan 26, 2009 | 05:51 PM
Re: CONFUSED
It was off-site it was jegs or summit.
Old Jan 26, 2009 | 06:01 PM
project89's Avatar
Re: CONFUSED
ummm my 89 rs had 28 spline axles in the factory rear,i am the second owner of the car, and the rear has never been changed
Old Jan 26, 2009 | 06:04 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: CONFUSED
I was thinking that 89 was the change-over year. Some 26, some 28.
JamesC
Old Jan 26, 2009 | 07:28 PM
Re: CONFUSED
S10 trucks got 28 spline axles the same time the Camaro did, late '89 or early '90.
Old Jan 30, 2009 | 05:13 AM
Pat Hall's Avatar
Re: CONFUSED
No surprise there. The f-bodies were switched to 28 spline axles in the last few months of the 89 production run, so you probably just have a late-year 89 car. Bummed me out when I found 26's in my original 89 rear. I switched to a Torsen carrier and had to scrounge up a set of 28's to install it.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
